[FIXED] 2001 ACURA CL 3.2 CRANKS/ NO START
- tim.smith1
- Thank you received: 61
- tim.smith1
- guafa
- Thank you received: 80
I have read all this thread and had came to my mind two ideas. I always try to return to the basics (fuel flow / air flow / spark flow)
Do we have enough fuel flow? Yes, we do. Actually seems more than normal
Do we have enough air flow? we don't know. Could this be the cause of soaked spark plugs?
Do we have enough spark? Yes, we do
Idea # 1 Try to simulate more temperature than real. I usually take 5kohm potenciometer and reduce ECT voltage. That way pcm injects less fuel than real. IF injector pulse width changes, i would rule out pcm and would look for a bad sensor or mechanical issue.
Idea #2 Try to read MAF or MAP
- robert.lesaca
- Thank you received: 19
- tim.smith1
- tim.smith1
- guafa
Use the resistor/s in paralell with ECT sensor checking that temperature increases 40 degrees. that way you can see pulse width change. I don“t think without a potenciometer, you can start engine (because you need little changes in resistance/voltage to precissely change pulse width)
i have data pids of the map sensor and the baro reading they match what other method could i use to read them?
While cranking, you should see a significant vacuum (diference between baro and map).
- tim.smith1
tim.smith1 wrote: What trace is on what off that scope Tyler?
Sorry about that. :blush: Blue is relative compression, yellow is IGT for coil #1, green is injector #1.
- tim.smith1
- tim.smith1
- tim.smith1
Windshield washer tank connected to intake vacuum?
I know you checked timing, just want to verify that you eyeballed the mark on the crank too. I'm sure you did, but this thing should start....
- tim.smith1
- guafa
It makes sense the engine did not start. The point here is after you tried to start engine, were the plugs wet again? i mean, wet like with no resistors?
did you noticed different injector pulse width with and without resistors?
A few things I thought of today is as soon as I unplugged the ECT a code for it came up the one thing I have never seen is a code for the coils and I don't think I have seen for injectors I know I have had the key on with the coils unplugged and also I think with injectors unplugged I also don't recall seeing any codes for the map or the tps and I have cranked the engine over with those unplugged. Is this car that slow on codes with a sensor or component unplugged or should that bother me and lean me more towards ecm?
We don“t know yet if pcm is bad. I think at least is sending injection and ignition pulse, which should start the engine.
The fact that you have spark, air (confirmed by MAP drop), compression (180 psi) and fuel makes me think you have a fuel control issue. Again, were the plugs wet again?
event before the pattern repeats again. :huh:
I don't think It would alert me given different circumstances, just an observation.
I've got access to a TL of the same generation if you need data or waveforms to compare
- guafa
my next move would be get a potenciometer and precissely change ECT voltage. I know is not the root cause of what you are facing, but this drives me to a fuel control (pcm sensor) issue.
In fact, you mentioned you started this engine with brake cleaner, which makes me think there is not a mechanical issue.
- tim.smith1
- tim.smith1
tim.smith1 wrote: Last thing I find funny is I did get a code p1279 for the vtec system I know that controls timing could that cause a not start?
Not that I'm aware of. Maybe try disconnecting the VTEC solenoids, just for giggles.
I was considering an intake restriction, but that doesn't explain how you can get it going with brake cleaner, OR the 180 PSI compression. Or the MAP readings. Opening the throttle doesn't make any difference?
