[FIXED] 2001 ACURA CL 3.2 CRANKS/ NO START
- tim.smith1
- Thank you received: 61
- jreardon
- Thank you received: 198
so the 500mV in the graph means it was hitting around 5 amps.
- jreardon
- jreardon
- tim.smith1
- jreardon
- tim.smith1
- tim.smith1
- jreardon
tim.smith1 wrote: 2nd channel is on number 4 coil Control wire Brown in color. Most likely the plugs are wet. When I check fire on coils they are firing bright blue.
Hold a plug up, with an air gap to ground, and take a current ramp on just that one coil. I want to know if the turn on oscillations are supposed to be present on these coils. I'm genuinely curious now.
- jreardon
tim.smith1 wrote: So scope is loosing internet took picks with phone amp clamp on 1mv/10ma should see green trace on scope for settings
Did you type that correctly? 1mv /10ma ?
Can you test that brown wire again, plugged in and unplugged? That signal did not look right, although it did trigger the coil.
- tim.smith1
- tim.smith1
- jreardon
tim.smith1 wrote: this is a amp off battery and injector an coil off number 3 cylinder i hope it shows up. if i can improve image somehow please let me know
Someone please correct me if I'm wrong but shouldn't injection be taking place during intake stroke? Why is injection taking place within spark dwell time, which would be around compression stroke?
- tim.smith1
- tim.smith1
- jreardon
- jreardon
- jreardon
Think about it, if you're spraying fuel during compression stroke, the cylinder is not going to have any gas to burn when the spark goes off !
You have to spray it when the intake valve is open during intake stroke. Then intake closes, cylinder compresses air and gas, then boom
The only time I can think of to spray gas during compression stroke is on gas direct engines where the injector tip is inside the cylinder head, spraying against cylinder compression with it's own pressure to match !
- jreardon
My theory is the gas would not be as atomized as it could have been, had the fuel been injected through the intake valve as quickly as the injectors fired. Fuel just sitting there in a puddle, falling into the cylinder, would perhaps hinder proper ignition because it does not mix with the incoming air into the cylinder.
Perhaps this is why you have fuel soaked injectors maybe, i'm not sure.
Why? I've never gotten an answer that truly made sense to me.
