2006 FORD F-150 5.4L 3V Triton Multiple misfires
- cheryl hartkorn
- Thank you received: 130
- garypuppet1
1.) ABS light is on either one of the front wheel bearing sensors are bad or a short in one of the wires, I replaced the center rear ABS switch and tested wiring all is good.
2.) Heater core is going out. blows moisture on inside of windshield on passenger side. Never over heats does not use any antifreeze or water. I am not ready to tackle that project as of yet its been rather cold here in the evening when I get home and I believe this will take me a good 6 hours.
3.) Rear main seal is starting to show a little oil, but Im a die hard ford guy and I know they all do this at about 100,000 miles so not rush. Dont use oil between changes.
4.) Header is leaking on passenger side at outlet flange, Getting new exhaust once i figure the problem I have now.
- garypuppet1
- garypuppet1
- garypuppet1
garypuppet1 wrote: Ok guys I ran a compression test I have between 160 and 180 on each cylinder they all register the same the gauge bounces between 160 and 180. Sorry it took so long to respond just been working.
No problem, thanks for getting back to us! Glad to hear base compression is good, nothing catastrophic. If you have the opportunity, it might be worth doing a running compression test on #8, and compare it to another cylinder on the other bank. This will help rule out stuff like worn cam lobes and broken valve springs.
I still don't think you have a catalyst problem, as the fuel trims you posted were pretty even bank-to-bank, but I could be wrong. Maybe do a backpressure check? Before you spend a bunch o' money at the exhaust shop.
- garypuppet1
garypuppet1 wrote: How do I perform a backpressure test? also how do I perform a running compression test? At this point any test I can perform that would save me some money would be definitely be appreciated.
Since your 5.4L doesn't use an EGR valve, or have a DPFE sensor, your only choice for backpressure is to remove the upstream O2. Well, you could also drill a hole ahead of the catalyst, but that's not a very good option IMO.
Once you have the O2 out, use a backpressure gauge, or a regular vacuum gauge. The only real difference between the two is that the backpressure gauge set will come with an adapter to screw into the O2 outlet, for easier testing. Try renting one from the local parts store if possible? Check this video for more info:
Running compression involves having the gauge installed in the cylinder with the engine running (obviously), with the Schrader valve removed. This ends up being a good measure of how the cylinder is breathing. Generally, the reading you'll see is 1/2 to 1/3 of static compression, so somewhere around 60-85 PSI.
It doesn't have to be inside that range, necessarily, that's just the rule of thumb. Really, I'd just be interested to see how #8 compares to other known good cylinders. If all is mechanically well, then they SHOULD be nearly identical.
- cheryl hartkorn
- garypuppet1
- garypuppet1
This isn't a ScannerDanner video, but does a very good job of explaining how to use a vacuum gauge and what it's telling you.
This ScannerDanner video shows one method of testing for a restricted exhausting using a compund vacuum/pressure gauge.
The alternative method is to connect the vacuum gauge to a manifold vacuum source. (Thats below the throttle, as opposed to ported vacuum, which is in front of the throttle plate.)
You raise the engine to 3000 rpm. A vacuum decay, or steady reduction in vacuum at 3000 rpms indicates a problem with the engines ability pump air, presumably due to a restriction in the exhaust.
- garypuppet1
- garypuppet1
- garypuppet1
- garypuppet1
Lol! I was just doing that a Subaru!garypuppet1 wrote: . The chain is tight and the phaser was 100% quiet while running with the valve cover off. Truck ran for about 15 to 20 minutes with no valve cover and slung out 3-4 quarts of oil, which im sure my wife just loved seeing on the drive way.
I just reread this saga from start to finish, quite an epic.
All the testing consistently shows that there is control of the injector and ignition coil at #8.
You've got strong steady vacuum at idle, which is a good sign for the valve train. (Some earlier posts reported 17.5 lbs, but the latest is 25 at idle. Did something change here?)
Static compression also reinforces the sealing of #8
I'm wondering about a head gasket failure at this point like Cheryl had mentioned earlier.
You said the plugs were wet when you pulled them at one point, are you certain it was with fuel and not coolant?
I'm not criticizing you, just trying to gather all the info can without being there.
- Ben
- Thank you received: 215
- garypuppet1
- garypuppet1
