2006 FORD F-150 5.4L 3V Triton Multiple misfires
- garypuppet1
- cheryl hartkorn
- Thank you received: 130
- cheryl hartkorn
- garypuppet1
- cheryl hartkorn
- cheryl hartkorn
- garypuppet1
- garypuppet1
- garypuppet1
I'm curious about the readings you took at the #8 coil connector:
When the key is on the on position my amp meter shows 12.4 amps on both wires of the coil on plug on cylinder 8 when running it shows 14.4 amps.
Are you sure you meant amps, and not volts? 'Cause those readings suggest a dead short in the circuit. A voltage reading of the same value would make sense with the engine stopped and running. Not trying to nitpick, just want to be clear
So, this thing had the typical 'fishbite' ignition misfire before, and definitely runs worse now? Pretty sure the coil connectors aren't long enough to mix up between cylinders... You've moved coils and plugs... Noid light says control is there... Power balance test backs up the code... Love the testing you've done so far! All stuff I'd do in the same situation.
I see that you have an Actron scanner, does it have access to scan data? Even good ol' Global data will work. Mostly I'm interested in the fuel trims. This can give us an insight into how the engine is breathing. Speaking of, you could remove the upstream O2 sensors to check for a plugged cat. BUT, that's a huge pain on these trucks, so I don't want to suggest that yet
A quick relative compression check would be easy to do. No scope required, just floor the gas pedal, crank the engine, and listen to the cranking cadence. If there's an low compression problem, then you'll hear the engine 'skip' the low cylinder as it cranks. FYI, this test doesn't completely rule out mechanical problems, but it's a good direction test. Here's an example:
- cheryl hartkorn
If you're concerned about a sticking valve, it would show itself with a vacuum gauge. Even with a lean or ignition miss, a vacuum gauge would have a steady reading. A sticking valve would be indicated by a steady ticking of the gauge.garypuppet1 wrote: Yes it had a slight miss prior to tune up only under severe load, I mean throttle to the floor in gear. Also it had the shudder that these tritons are know for from misfire due to coil or plugs, that is why i decided to give it a complete tune up. Like i said not only did change the plugs once but i changed them twice and have rotated the plugs as well as the coils to see if it follows the plug or the coil, it made no difference. I also used a mechanics stethoscope down the valve covers and heard no noises like valve springs. the phasers are relatively quiet no excess noises and ran the stethoscope down the front timing chain cover and no noises. I thought maybe i had a stuck valve or valves on cylinder 8 but Im not sure how to trouble shoot or diagnose it means how I have no valve noises.
Also, when I first got my Navigator, I went batty looking for the cause of a wot skip. It felt just like when a Ford cop was going bad, but only under heavy acceleration, like when passing on the highway. Long story short, it had a junk tire, so I replaced it with one of the correct size, but that was worn considerably less than the other 3.
There is no 2hi mode on the transfer case, only A4WD (automatic four wheel drive). It didn't like that one nice tire while it was trying to split torque between the front and rear axles and felt just like a misfire.
- garypuppet1
ABS LOAD(%) 16.9
ABS TPS B(%) 20.0
ABSLT TPS (%) 13.7
ACC POSS D(%) 19.6
ACC POS E (%) 29.8
ACC POS F (%) 19.2
BARO PRS ("HG) 30.4 , I live in Ohio, i think this should be higher
CALC LOAD (%) 20.8
CAT TEMP11 (F) 895
CAT TEMP21 (F) 894
CLR DIST (mi) 0
CLR TRPS 0
CMD EQ RAT 0.999
COOLANT (F) 153
ENG RUN (m:s) 04:39
ENG SPEED (RPM) 674
EVAP PURGE (%) 15.3
EVAP VP (H2O) -0.034
FUEL LEVEL (%) 48.2
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
IAT (F) 34
IGN ADV (o) 10.0
LT FTRM1 (%) 0.8
LT FTRM2 (%) 3.1
MAF (LB/M) 0.82
MIL DIST (mi) 0
MIL STATUS OFF
O2S11 (V) 0.100
O2S12 (V) 0.395
O2S21 (V) 0.050
O2S22 (V) 0.785
OBD2 STAT CA
OUT TEMP (F) 12
REL FRP (PSI) 39.23
REL TPS (%) 2.0
ST FTRM11 (%) 2.3
ST FTRM21 (%) 5.5
ST FTRM1 (%) -2.3
ST FTRM2 (%) -0.8
THROT CMD (%) 3.1
VEH SPEED (MPH) 0
VPWR (V) 14.653
Fuel pressure looks good, and the trims are surprisingly reasonable for having two misfires. I was honestly hoping to see higher trims on bank two, suggesting a lack of spark or fuel
Any luck with the relative compression test? I also like Noah's idea of the vacuum gauge. I saw that you listened to the valve covers, but I know that broken valve springs are common-ish on this engine, so it's still on my mind. We can also go further into mechanical stuff once you get the compression gauge, of course.
- garypuppet1
Misfire count cylinder 1 : 7
Misfire count cylinder 2: 6
Misfire count cylinder 3: 0
Misfire count cylinder 4: 0
Misfire count cylinder 5: 5
Misfire count cylinder 6: 1
Misfire count cylinder 7: 194
Misfire count cylinder 8: 2131
- garypuppet1
- garypuppet1
- cheryl hartkorn
Thinking about an injector problem, maybe you could pull the #8 plug again and see if it's wet with fuel? This would at least tell us that the injector is spraying something.
- garypuppet1
