Rich and lean at the same time
  • pquick
  • pquick's Avatar Topic Author
8 years 8 months ago #17287 by pquick
Replied by pquick on topic Rich and lean at the same time
all the coils are firing and have good ramp shape and look good. Plus they are all new.
8 years 8 months ago #17297 by juergen.scholl
Replied by juergen.scholl on topic Rich and lean at the same time
A secondary ignition waveform will show what's happening in the combustion chamber, from A/F ratio up to compression. ... I understand you measured the primary amp draw of the coils but this is completely different from a secondary. Can u get a secondary waveform from each bank under similar conditions?
  • pquick
8 years 8 months ago #17383 by pquick
Replied by pquick on topic Re:Rich and lean at the same time
I get .7 lb/ per min at Idle and 19 lb/ min at WOT in third gear.
  • pquick
8 years 8 months ago #17384 by pquick
Sorry I had to borrow a scanner last time to get to see the primary side. My little scanner doesn't show scope info. I will try and borrow again
8 years 8 months ago #17390 by Ben
Replied by Ben on topic Re:Rich and lean at the same time
Converting that to grams that's 5.2 grams a second at idle and 143 at wide open throttle which is low for a v8 I believe were in need of a good maf cleaning
Time to create page: 0.249 seconds
