Rich and lean at the same time
  • pquick
  • pquick's Avatar Topic Author
8 years 8 months ago #17247 by pquick
Rich and lean at the same time was created by pquick
I am working on a 2003 F-150 with a 4.6L engine. Bank 1 has a long term fuel trim of -25, Bank 2 has a long term fuel trim of +19. Computer is sending an engine code PO172 (rich condition bank 1). O2 sensors both send good oscillating data (0.8-0.01 on a 3 second interval) and have been replaced for good measure. Vacuume test shows good, fuel pressure test shows good, all coils test good and new spark plugs, smoke test intake mannifold no leaks, new egr, MAF send good signal, PCV new hose ends and valve (no leaks). Also replaced all injectors just to rule out plugged and leaking problems.
This truck is running OK (slight rich miss at idle) but definitely gets bad gas mileage (12 mpg HWY). the only problem I can find is that the computer is opening the purge solenoid all the time even at idle. I unplug it but the rich fuel trim problem continues and makes no difference in fuel economy.
Any suggestions?
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 8 months ago #17249 by cheryl hartkorn
Replied by cheryl hartkorn on topic Rich and lean at the same time
what about a restricted cat?? also how about timing on the negative bank??
  • cheryl hartkorn
8 years 8 months ago #17250 by cheryl hartkorn
have you tried to reset the keep alive memory
  • graywave
  • graywave's Avatar
8 years 8 months ago #17252 by graywave
Replied by graywave on topic Rich and lean at the same time
Are the long term fuel trims you mention at idle? What are the short term trims?
If you raise the RPMs what do the fuel trims do then?
8 years 8 months ago #17253 by juergen.scholl
Replied by juergen.scholl on topic Rich and lean at the same time
What exactly is "good vacuum"? You got numbers? Can you do a cylinder contribution test with a scantool? Did you PLUG the evap line to the intake manifold instead of unplugging it electrically? Maybe the purge solenoid is stuck open? What is the compression? Can you do a relative compression test in order to compare bank to bank?
Rich and lean codes at the same time do have 3 main causes:
1- timing jumped ( on one bank)
2 - plugged exhaust on dual systems
3 - evap purge solenoid stuck open ( this affects both banks equally, not
differentially)
  • pquick
8 years 8 months ago #17262 by pquick
Replied by pquick on topic Rich and lean at the same time
yes reset KAM a couple of times and it goes right back to extreme rich lean condition on long term fuel trim
  • pquick
8 years 8 months ago #17263 by pquick
The vacuum test is steady at 20 at idle, drops to 5 with throttle snap. stays steady at 24 at 3000 rpm. Plugged into the brake booster port. This rules out intake manifold leak, timing problems, burnt valves, and a plugged cat.
  • pquick
8 years 8 months ago #17264 by pquick
Short term Fuel trim B1 bonces +1.6 to -0.8% (LT -25%)
Short term B2 bounces +2.0% to -3% (LT +15)
Timing at idle 10-17* ( at 300 rpm 23*)
Load at Idle 35%. Load at 3000 rpm 21% (parked)
  • pquick
8 years 8 months ago #17265 by pquick
Problems I notice
1. goes into CL with in 30 sec's of starting no matter how cold temperature is. (engine temp sensor accurate and test good)
2. Will not pass evap test. " PCM unable to control engine RPM" So I replaced IAC and got the same problem only worse drivablity. Computer would randomly hold RPM above 1500 (like having cruise control stuck on). Had to use brake and clutch to stall engine then it returns to normal RPM. Cleaned and put old IAC back on and it works better than the new one but will not pass test for evap.
3. this truck has old school timing. Not variable valve timing. I can't imagine it going mechanically out and still be able to run at all.
  • pquick
8 years 8 months ago #17266 by pquick
Purge solenoid test good (dose not leak and I can turn it on and off electrically). I plugged the line just to make sure and it did not change fuel trims.
  • pquick
8 years 8 months ago #17267 by pquick
sorry my messages are so broke up I tried typing this out in one post and it logged me out.
The rest of the Evap system seems to be good from the carbon canister to vent valve to vacuum testing the tank sensor and cap.
the other mechanics in the shop believe that the computer is messed up and I should replace that next. I have wasted so much time and parts on this truck I want to make sure I have exhausted all other options before I get a computer.
  • pquick
8 years 8 months ago #17268 by pquick
Parts that I have replaced: Spark plugs, coils, fuel injectors, O2 sensors, IAC (but put the old one back on), fuel filter, oil change (was not fuel contaminated), EGR, Air filter (was very dirty), cleaned throttle body and MAF sensor (sends good signal), reset KAM three separate times, replace PCV and hose ends ( the hose end on the back of the manifold was bad and this is the original problem the truck came in with besides the dirty air cleaner).
  • pquick
8 years 8 months ago #17269 by pquick
I also checked all my grounds (seem to be clean, tight, and not corroded) and put new battery and battery cable ends on (professional solder on HD cable ends NOT clamp-on's)
  • pquick
8 years 8 months ago #17270 by pquick
TPS also seems to be sending good signal changing with petal position in gradual increments.
  • pquick
8 years 8 months ago #17271 by pquick
To add insult to injury. The hood and the roof of the cab of this truck got lightly damaged, by a piece of metal roofing blowing around, while in my care, so I ended up buying the truck from the customer to make them happy and not have to turn it over to insurance. So now I'm not getting paid for this job, I"m only losing more money and feeling kinda dumb.
  • pquick
8 years 8 months ago #17274 by pquick
I also looked at cylinder balance and they all are with in tolerance, #1 and #4 take turns missing at idle (some times). Some times there is no miss at all, and sometimes #6 misses all by it's self a little at idle. Its not all the time and it is very random so it leads me to believe that fuel is being turned on the rich side creating a rich miss that can only be felt at idle, and maybe #1 is a lean miss sometimes.
Fuel pressure tests good and does not bled off when turned off
  • pquick
8 years 8 months ago #17275 by pquick
Parked At 2500 rpms held throttle steady for 1min: LT B1 -21% / LT B2 +12.5% Short terms on both are bouncing back and for +/-
8 years 8 months ago #17280 by juergen.scholl
Can you scope the secondary ignition?
The following user(s) said Thank You: pquick
8 years 8 months ago #17282 by Ben
Replied by Ben on topic Re:Rich and lean at the same time
What is your maf readings at idle warm engine and a 1st/2nd gear wide open throttle run you should idle see between 5 and 6 grams at idle and on that engine I expect to see close to 200 grams on a wide open throttle run
  • pquick
8 years 8 months ago #17286 by pquick
Replied by pquick on topic Re:Rich and lean at the same time
I will not get to test this today but will get back to you as soon as possible. thanks
Time to create page: 0.325 seconds
