[FIXED] Explorer no spark - confirm my diagnosis
  • Exranger06
  • Exranger06's Avatar Topic Author
10 years 1 month ago #1918 by Exranger06
Replied by Exranger06 on topic Explorer no spark - confirm my diagnosis
No worries, I also wanted to exhaust every other possibility before towing it anywhere to be reprogrammed. I was really hoping it wasn't a bad ECM because I really didn't want to tow it again. I will update with any more findings and/or conclusions.
  • Exranger06
10 years 1 month ago - 10 years 1 month ago #1923 by Exranger06
Update: New ECM arrived in the mail today and I wasted no time installing it. First thing I noticed: the check engine light turns off while cranking, which was not happening before. Second thing I noticed: live data on my scanner shows RPM while cranking, also something that wasn't happening before. I checked the ignition coil connector, and I have a pulse! I hooked up the spark tester and there is spark once again!
There is still no injector pulse, which no doubt is due to the PATS not letting the injectors fire. The Theft light flashes and I have a P1260 code, as expected. I'm going to call this officially diagnosed! I'll give this thread another update when I get the PATS reprogrammed and the engine finally starts. I'm not sure when I'll have the time and money to tow it somewhere to get that done, but I'll update when I do. Thanks for the help, everyone!
Last edit: 10 years 1 month ago by Exranger06.
10 years 1 month ago #1926 by Tyler
Replied by Tyler on topic Explorer no spark - confirm my diagnosis
Exranger06 wrote: Update: New ECM arrived in the mail today and I wasted no time installing it. First thing I noticed: the check engine light turns off while cranking, which was not happening before. Second thing I noticed: live data on my scanner shows RPM while cranking, also something that wasn't happening before. I checked the ignition coil connector, and I have a pulse! I hooked up the spark tester and there is spark once again!
YAY! That's exactly what I wanted to hear!
Congratulations to you, sir - That was NOT an easy diagnosis. This'll be the first case I've heard of a PCM that just won't receive a signal from a functioning sensor :huh:
I'm gonna consider this fixed if that's cool with you?
  • Exranger06
10 years 1 month ago #1938 by Exranger06
Yes that's fine with me
10 years 1 month ago #1993 by Noah
Replied by Noah on topic Explorer no spark - confirm my diagnosis
Great news, sure sounds like a fix to me. Looks like you had it right all along, nice work indeed.
Time for a beer!
  • Exranger06
10 years 1 week ago #2792 by Exranger06
Final update: I finally towed it to the Ford dealer on Thursday. They reprogrammed the computer, and it now starts and runs. Officially fixed!
10 years 1 week ago #2804 by Tyler
Happy to hear it, sir! Also glad to hear the dealer didn't give you any static as far as the PATS programming.
Was always kinda disappointed that Ford didn't provide some kind of manual relearn procedure, like GM's 30 minute procedure. Sure, it takes awhile, but it's better than a trip to the dealer.
10 years 1 week ago #2812 by shayne.johnston
Replied by shayne.johnston on topic Explorer no spark - confirm my diagnosis
Tyler wrote: Happy to hear it, sir! Also glad to hear the dealer didn't give you any static as far as the PATS programming.
fyi snap-on scanner can now do some of the PATS programming on fords.
10 years 6 days ago #2816 by Noah
my rep told me about that with my last update, I haven't had the opportunity to try it out yet myself. Thanks.
