No Click Crank or Start
8 years 10 months ago #15646 by Chad
Replied by Chad on topic No Click Crank or Start
Did Fuse 201 have power with the key in the START/CRANK position?
The following user(s) said Thank You: swilson7674
8 years 10 months ago #15647 by Chad
swilson7674 wrote: I have not tested the DTR in that manner.
Are you familiar with the term "Back-Probing"?
8 years 10 months ago #15677 by Noah
Replied by Noah on topic No Click Crank or Start
The testing methods in this video may help you to familiarize yourself with some of techniques you'll need to check the crank circuit and ignition on your Lincoln.
8 years 10 months ago #15678 by Noah
  • swilson7674
  • swilson7674's Avatar Topic Author
8 years 9 months ago #16221 by swilson7674
Replied by swilson7674 on topic No Click Crank or Start
201 did have power when i turned key to crank position. So now i suppose its time to test the DTR sensor. What is the proper way to test that part/circuit
8 years 9 months ago #16229 by Chad
Power from Fuse 201 should go INTO the DTR on Pin #10 (GRY/ORG). If in Park or Neutral, power should come OUT on Pin 12 (GRY)
Back-probe these wires and check for battery voltage, while in the crank position.
This is ScannerDanner Back-Probing a solenoid connector.
This is ScannerDanner piercing a wire to take a voltage reading.
If you pierce a wire that is exposed to the elements, be sure to seal the hole with liquid tape, or similar. Water intrusion will cause corrosion.
  • swilson7674
8 years 8 months ago #17436 by swilson7674
Replied by swilson7674 on topic No Click Crank or Start.
pole71 wrote: Power from Fuse 201 should go INTO the DTR on Pin #10 (GRY/ORG). If in Park or Neutral, power should come OUT on Pin 12 (GRY)
Well, I've had some trouble getting back on here. However in regards to the DTR sensor I have voltage at pin10 but 0 at pin 12 gray wire. I need this car to run in the worst way. So what do I do next
8 years 8 months ago - 8 years 8 months ago #17442 by Chad
Replied by Chad on topic No Click Crank or Start.
swilson7674 wrote: in regards to the DTR sensor I have voltage at pin10 but 0 at pin 12 gray wire. I need this car to run in the worst way. So what do I do next
If you have power at Pin 10, but not at Pin 12, verify that you are in Park or Neutral. You can try to adjust DTR position by loosening the fasteners and slightly rotating the DTR on way, or the other. If still no power on Pin 12, while in the "Crank" position, replace the DTR.
Last edit: 8 years 8 months ago by Chad.
  • swilson7674
8 years 8 months ago #17461 by swilson7674
If you have power at pin 10 and none at 12 that definitely points to the DTR? I have it so the lines on the sensor are aligned in neutral. The sensors I've been trying are salvage yard parts.
8 years 8 months ago - 8 years 8 months ago #17462 by Chad
swilson7674 wrote: If you have power at pin 10 and none at 12 that definitely points to the DTR?
Power goes in. Power does not come out. Applying and alternate power source to pin 12 cranks the starter. I would be confident in replacing the DTR.
The only other possibility, that I can think of, is Female-to-Male pin connections. With the connector disconnected, and a multi-meter set on ohm, do you see continuity between Pins 10 and 12 of the DTR?
If I am missing, or overlooking, something, I am sure someone will chime in.
  • swilson7674
8 years 8 months ago #17502 by swilson7674
Do you happen to know if a DTR sensor for a 2000 is the same for later model years. The salvage parts I have are from 01 and 02 models. They are missing pin #1. I don't know if it matters or perhaps there were changes made to that part. Just a thought.
  • swilson7674
8 years 8 months ago #17670 by swilson7674
I applied power to terminal 12 of the DTR connector, however I did it in a stupid way. So I connected a wire from battery to the unconnected DTR connector and I also disconnected my negative battery cable. So when I went to test if the engine would crank I connected the battery and opened the door which triggered the alarm however the engine kept trying to crank but PATS system kept killing it and after that I couldn't get it to crank again. I'm wondering if I blew a fuse or relay or do I have to reset the PATS system? I guess the main thing is, is that it did want to crank when power was applied to terminal #12. Any thoughts ?
