'05 Acura TSX DTC 54-50
- Online
Tutti57 wrote: Thanks for looking into that. The front or rear door sills? My codes did indicate 1st and 2nd, so we will have to see what that means.
Front sills, I believe. I hate the way Honda designated these sensors. :silly:
- Tutti57
- Thank you received: 254
So mad that my tool crapped out right now. I need to get another back up.
- Tutti57
- Online
Also, really sucks to hear about your Launch.
- Tutti57
Yeah, that's what I'm thinking too. It would explain the odd behavior.Tyler wrote: Crap.
Now I'm really starting to wonder if this module is set up for the wrong vehicle. Let us know what the module company says?
Also, really sucks to hear about your Launch.I've had to send the Modis off a couple times, so I know what it's like to be without your scanner. :silly:
They said those aren't hard codes and I should be able to delete them, but I can't. They also asked if I replaced the sensor and I said i did. Their final question was the module part number. I sent them what it should be but have to take the dash partially back apart to get the number off what is on there now.
- Tutti57
A side not about my scanner - it was very weird and the second time this has happened. It sort of froze up and when I tried to power down, the screen went black and appeared to be off but now I seems like it never was. I can volume down and it vibrates like it went to vibrate mode but the screen is still black. The first time this happened I shipped it out and they said they charged it and it was fine. Obviously I tried this with different chargers and everything. This time, I didn't send it out right away and after a couple of days I tried powering it up for the hell of it, I got the low battery display. I charged it up and now it's fine. I'm thinking that when it freezes up like that it just won't shut down and when the battery dies it's all good again. Weird but I'm glad I didn't ship it out for repairs!Tyler wrote: Crap.
- Tutti57
"No if that was the case it would read" can't communicate with unit. Sometimes it happens that once plugged into the vehicle it will acquire new hard codes and needs to be cleared again.it rarely happens but appears to be the case with yours. I will need he unit back to have it reprogrammed."
...so I'm sending it back to them.
- Online
- Tutti57
Could I have not followed a specific procedure putting it back in? All I did was disconnect the neg battery terminal.Tyler wrote: I wonder how a module could 'acquire' new hard codes? I'm not saying that's BS, necessarily, because I know that SRS modules play by somewhat different rules than others. Mostly just wondering about the module's programmed logic. :huh:
- Tutti57
I just got the module back from the company for the second time. They assured me that there were no codes in it and I am getting the same three popping up. Maybe there is another sensor and the one I replaced wasn't one of the bad ones. I have to figure out what this 1st and 2nd sensor nonsense is. The wire diagram only shows 4 impact sensors, so the numbers are weird.Tutti57 wrote:
I forgot to mention last time that my scantool says codes have been deleted, then the light instantly comes back on and now I can't communicate with the module. I can with others but now I can't with the srs. I wonder if I got a bad used module.
- Tutti57
I'm actually thinking that the sensor I put in is bad. I'm going to try swapping another one tomorrow to see if that helps. I was able to clear the codes and after a couple of cycles they came back. Maybe I'll be able to get the scope on it.Tutti57 wrote:
- Tutti57
- Online
I mean, I'm happy for you either way! I wonder what the wiring differences are between the two. I'll look that up when I get home.
- Tutti57
I don't even know now. I bought a used one that said it fit 2004- like 2009 and now when I look up the part number that's on, it it comes up as a 2004 and I have a 2005. It looks like the part numbers are different but I see tons of listings grouping all of the years together and can't find anything with the part number I'm seeing on the OEM Acura parts website.Tyler wrote: Wait, so... It had the wrong module in it the whole time? Or they sent you the wrong one? :huh:
Before I realized this I unplugged the right front sensors and got a code for no signal. Then I moved a "bad" sensor to the other side that doesnt have a code and the fault didn't move, which is weird.
I'm going to look at a diagram to compare the two years.
Here is what I have now.
- Tutti57
Damn, the diagrams look the same. I don't know what is up with these part numbers.Tutti57 wrote:
- Tutti57
A little more info. My part number was replaced by this one, so I don't think it would be an issue.Tutti57 wrote:
- Tutti57
Summary to catch everyone up, including what I just did today with it.
Car had a srs module internal fault code
Replaced srs module with used unit
Paid to have hard codes cleared
Now have 3 impact sensor internal fault codes
Replaced front right side sensor with 3 different sensors (all used) code does not go away, come right back after clearing
Swapped "bad" side sensor to the front left and the code did not love with it. Odd. Only thing about this is that the sensor was not bolted in and I don't know if there is some grounding needed there.
Installed another used module and still have the 3 impact sensor codes
When I pull the harness off of the side sensor the code changes to a no signal from impact sensor
At one point after pulling the sensor harness and clearing the codes a single new one came up opd system internal fault
I initialized that part with my scan tool and codes are gone until I key on again, then the 3 impact codes come back.
I hate that I'm using used parts here to have that factor in but these damn things are expensive!
The only other thing I can think of is that the srs module has three plugs in it and 4 slots. I don't remember there being 4 connectors but I'm going to look at the diagram again to see if I can figure that out.
Thoughts?
- Tutti57
Tutti57 wrote: I have had it with this one!
Thought?
- Tutti57
What do you mean?sebastianshaw wrote: Try to use the -REMOVED- :whistle: Happens once in a while
- Online
Mostly just trying to figure why it'd suddenly throw the OPDS code in there.
