2013 BMW Help
- oneilsgarage
2 years 2 weeks ago #67145
by oneilsgarage
Replied by oneilsgarage on topic 2013 BMW Help
updated scan as of today
ECM (Engine Control Module - DME/DDE) 9 problems exist
1.CD9010 LIN, Message; Electric Coolant Pump: Missing Permanent
2.140010 Combustion Misfires, Several Cylinders: Detected Intermittent
3.164041 Exhaust Camshaft: Installation Defective Intermittent
4.120408 Charging Pressure Control: Switch-Off As Consequence Intermittent
5.140310 Combustion Misfire, Cylinder 3: Detected Intermittent
6.140410 Combustion Misfire, Cylinder 4: Detected Intermittent
7.140001 Misfire, Several Cylinders: Fuel Injection Is Cut Out Intermittent
8.140301 Misfire, Cylinder 3: Fuel Injection Is Cut Out Intermittent
9.140401 Misfire, Cylinder 4: Fuel Injection Is Cut Out Intermittent
- Monde
- Thank you received: 43
2 years 2 weeks ago - 2 years 2 weeks ago #67147
by Monde
Replied by Monde on topic 2013 BMW Help
You are not losing spark on 3 and 4, are you?
Just looking for direction.
Last edit: 2 years 2 weeks ago by Monde.
- oneilsgarage
2 years 1 week ago #67150
by oneilsgarage
still have spark and fuel, l'm thinking DME internal fault at this point
- Monde
2 years 1 week ago #67153
by Monde
Did you swap the injectors? Since the faults are intermittent, make sure the connectors are clean and tight with good pin fitment. You may have to wriggle the wires to look for dropouts.
- oneilsgarage
2 years 6 days ago #67220
by oneilsgarage
thanks Monde for trying to figure this issue out, we determined that the motor jumped it's timing and currently installing new new chain and guides.
Time to create page: 0.332 seconds
