2013 BMW Help
  • oneilsgarage
  • oneilsgarage's Avatar Topic Author
2 years 4 weeks ago #66949 by oneilsgarage
2013 BMW Help was created by oneilsgarage
We have a customer come in with a 2013 BMW 320i 2.0L , they had replaced plugs coils and all 4 injectors but its running on 2 cylinders and throwing codes.
(please see attachment.) l'm lost where to start we tried a new intergrated power supply module that BMW tech said to try but still does the same thing. please help.
This browser does not support PDFs. Please download the PDF to view it: Download PDF
2 years 4 weeks ago #66950 by Monde
Replied by Monde on topic 2013 BMW Help
Do the 2 cylinders have good compression?
  • oneilsgarage
2 years 4 weeks ago #66952 by oneilsgarage
Replied by oneilsgarage on topic 2013 BMW Help
don't have the proper compression tester honestly,
2 years 4 weeks ago - 2 years 4 weeks ago #66955 by Monde
Can you do a cranking  compression sound test?
Last edit: 2 years 4 weeks ago by Monde.
  • oneilsgarage
2 years 3 weeks ago - 2 years 3 weeks ago #66961 by oneilsgarage
compession has followed:
Cyl#1 -150
Cyl#2 -155
Cyl#3 -150
Cyl#4 -165
Last edit: 2 years 3 weeks ago by oneilsgarage.
2 years 3 weeks ago - 2 years 3 weeks ago #66964 by Monde
Do you have good wiring integrity  to the coils and injectors in question? What are the codes that you are getting?
Last edit: 2 years 3 weeks ago by Monde. Reason: Rewording
  • oneilsgarage
2 years 3 weeks ago #66965 by oneilsgarage
think l might of found the issue the EKPM3 Module has power going in but out to the low pressure fuel pump
2 years 3 weeks ago #66966 by Monde
So, you think that you are missing a feed to the low fuel pressure pump?
  • oneilsgarage
2 years 3 weeks ago #66987 by oneilsgarage
I found a test procedure on google , and found that with the ignition on l had no power referance on the orange wire at the fuel pump
2 years 3 weeks ago #67011 by Monde
Try checking the power feed to the fuel pump at the fuel pump control module. If it is still not there, you will have to check power(s), ground(s) and communication lines to the module. If the vehicle runs, I would assume that the pump has power and ground.
  • oneilsgarage
2 years 2 weeks ago #67050 by oneilsgarage
pump does not run with key on
2 years 2 weeks ago #67057 by Monde
The module is not powering the low pressure fuel pump with key on. Did you check for voltage at the module itself? We are just trying to see if there is a wiring integrity problem. If you don't get voltage at the module, you isolate the circuit and check for a short to ground. If everything checks out, you will have to check power, ground and communication lines to the module. Good luck
  • oneilsgarage
2 years 2 weeks ago #67062 by oneilsgarage
we tried to program the new module today the set up used was you setup this box module with power supply built in can;t remember the namew but it was snapon. the guy called back ran the test and said he can't program it , we put the old one back in and he said it tested fine and that there was a wireing issue with the DME
2 years 2 weeks ago #67065 by Monde
I have just realized that there was a bunch of codes.
  • oneilsgarage
2 years 2 weeks ago #67090 by oneilsgarage
i'm having a hard time with identifix finding what wire on the DME controls power feeds to the injectors and voltage on them pins should be with key on or in crank mode
2 years 2 weeks ago - 2 years 2 weeks ago #67131 by Monde
If we have the same wiring diagram: pins 9,10,11 and 12 (all white wires) at the DME, connector 6B should be power feed to the injectors. You can check voltages on the ones that work to know what to expect on the ones that do not work. Battery voltage should be expected. Have you tried erasing the codes and see which ones that come back?
Last edit: 2 years 2 weeks ago by Monde.
  • oneilsgarage
2 years 2 weeks ago #67137 by oneilsgarage
l've checked for power and ground at the injector plug on 3 and 4 that l have the issue with , battery voltage and ground are present.
2 years 2 weeks ago #67140 by Monde
Are you missing sparks on 3 and 4? If yes, check coil wirings integrity. If everything checks out, swap 3 and 4 with 1 and 2 and see if the misfires move. If you are not missing sparks, swap the injectors.
  • oneilsgarage
2 years 2 weeks ago #67141 by oneilsgarage
should l do this if theres new plugs,coils and injectors?
2 years 2 weeks ago - 2 years 2 weeks ago #67143 by Monde
I replaced two brand new coils in a friend's car. Both of them were bad. You can have bad new parts. The thing is that if you have powers and grounds to the injectors, good compressions, powers, grounds and transistor controls to the coils, you either have bad coils or bad injectors unless you a a vacuum leak affecting the 2 cylinders which would probably get better as engine warms up.. If you have weak drivers in the DME or the DME cannot process some information properly, you can have a bad DME.
Time to create page: 0.398 seconds
