Nissan Frontier 1998 manual trans and 2.4 liter has a high idle and no comms
  • Marti
  • Marti's Avatar Topic Author
2 years 3 months ago #65988 by Marti
My Frontier has no communication with either diagnostic port (16 pin port or the Nissan Consultant port) so no scanner works (I tried several scanners).  I replaced a 7.5 A fuse that had been blown and that feeds 12 V to the 16 pin diagnostic port.  My symptom is a high idle (1,500 rpm at all times).  It began to have a high idle after running fine for years.  When I start the truck, I now hear multiple clicks from a blue solenoid under the dash, then the truck idles high all the time.  I tried replacing the blue solenoid with no improvement.  There is very little power when driving now.  I replaced the inlet air control IAC valve with no improvement.  I replaced vacuum lines and looked for vacuum leaks with no leaks found yet.  Do you think the throttle position sensors could be causing this condition?  I have various scanners that can be remote onto (Autel BT609 that is about 3 years old, a Topdon Pheonix Plus that is new).  Marty 850/597-1316.
2 years 3 months ago #65995 by Lupe
Marti is fuse 11 good? maybe try to get ob connector fixed first to help you . I think you got map sensor and soldnoid on that truck check both also a miss fire will give high idle i think with map . good luck
2 years 3 months ago #66000 by Noah
Did replacing that fuse restore communication with the scan tool?
Is there now power on pin 16?
I'm with Lupe, I would probably go after the no com first to gain some direction.
  • Marti
2 years 3 months ago #66011 by Marti
Yes there is now power on the 16 pin OBD port and the two grounds are there but no communication with any scanner. I'll attach a wiring diagram of this system in my next message, about 6 PM today. Thanks
  • Marti
2 years 3 months ago #66012 by Marti
I will check the manifold air pressure (MAP) sensor and wires today after 6 pm. What do you mean by solenoid in your reply? Quote: "map sensor and soldnoid." Is that the idle air control (IAC) solenoid you are referring to? I replaced that with no reduction in idle speed.
  • Marti
2 years 3 months ago #66023 by Marti
Im just wondering if I am able to post wiring diagrams that I have from my subscription to Automotive Electricians Portal? I don't know if there is a prohibition on posting materials that I have a subscription to, but I guess not...
2 years 3 months ago #66025 by Noah
There has been no issue posting diagrams here on the forum.
  • Marti
2 years 3 months ago - 2 years 3 months ago #66027 by Marti
Here is the wiring diagram from automotive electricians portal
Last edit: 2 years 3 months ago by Marti.
  • Marti
2 years 3 months ago #66028 by Marti
Yes, fuse 11 is 12 volts on each side so it's good. I looked at the MAP sensor and solenoid and there is 12 v on one wire and 0 volts (a ground?) on the other wire. When I unplugged it the truck ran very poorly, so I think it is functioning to some degree. Is there a resistance measurement I need to make on it? thanks
  • Marti
2 years 3 months ago #66046 by Marti
I've checked the MAP sensor solenoid and it clicks when KOEO. I then checked the absolute barometric pressure sensor which shares a vacuum hose with the previous sensor/solenoid. It shows a good ground. Next I'll back probe the sensor line and apply a vacuum and see if the volts on the signal wire drop under vacuum..
  • Marti
2 years 3 months ago #66047 by Marti
Also, fuse 7 has no power on either side of the fuse, either with KOEO or with engine on.
  • Marti
2 years 3 months ago #66129 by Marti
Any suggestion on getting communication on either the OBD2 or Nissan Consult connector for diagnostics? Do I look for resistance with all the power off? Which pins do I check ohms, and which of the 2 diagnostic ports...
2 years 3 months ago #66131 by Monde
How about the K-Line on the 16 pins connector (OBD2)? If you have a breakout box, you could  connect the scanner on the obd2 port and see if you have activity on pin 7 at the box when you are attempting to communicate. Since the truck runs, most likely the resistors are fine. If you want to check them, ohm pin 6 and 14. 60 ohms is ideal.
2 years 3 months ago - 2 years 3 months ago #66132 by Chad
There is not much to the communication with the ECM via the OBD2 DLC.
First, make sure that you have good battery voltage on Pin #16, and good grounds on Pins #4 and #5 of the DLC.
Next, as Monde suggested, check for voltage activity on Pin #7.
The K-line (pin #7) should have 12 volts when there is no network activity,  and toggle to ground with communication.
That's all there is to it. If you find you have nothing on Pin #7, you need to go to the ECM, Pin #69, and check there.
Last edit: 2 years 3 months ago by Chad.
  • Marti
2 years 3 months ago #66196 by Marti
This is good information, I will check for 12 v on the K line and provide an update.
  • Marti
2 years 3 months ago #66230 by Marti
With key on engine off (KOEO) there is 7.7 volts on the K line (pin 7). It goes to about 9 volts with engine on. Pin 16 shows 12 v with KOEO and 14 volts with engine on. The two can lines 6 and 14 show no continuity with the ohm meter connected between these pins. What's the next test?
  • Marti
2 years 3 months ago #66231 by Marti
I did not have the scanner on and trying to communicate when I tested the pin 7 of the OBDII connector. Should I try to put an oscilloscope on pin 7 and try to communicate?
2 years 3 months ago #66232 by Monde
Do that and see if the voltage drops as the scanner tries to communicate.
2 years 2 months ago #66238 by Chad
 A quiet, idle K-line should have 12 volts. If you are using a volt meter, and there is something that is trying to communicate, such as a "babbling node",  you could be reading the average of a square-wave.
Yes. That will answer the question of whether you have low voltage on the K-line or, if there is something trying to communicate.
This vehicle does not use CAN. Pins 6 and 14 are not used.
  • Marti
2 years 2 months ago #66315 by Marti
im having trouble with posting to the forum. I don't know what my user ID is so I am unable to send a request to support.
Time to create page: 0.400 seconds
