Test question
  • Dylan
  • Dylan's Avatar Topic Author
  • Belgium, Europe
9 years 7 months ago - 9 years 7 months ago #7564 by Dylan
Test question was created by Dylan
Ok. Let's start with an easy one :)
In a certain digital waveform, the period is four times the pulse width. The duty cycle is ______?
A= 0%
B= 25%
C= 50%
D= 100%
Last edit: 9 years 7 months ago by Dylan.
9 years 7 months ago #7579 by Knoxtech
Replied by Knoxtech on topic Test question
C
9 years 7 months ago #7589 by Tyler
Replied by Tyler on topic Test question
B? :huh: I gotta go read up on duty cycle now. :lol:
9 years 7 months ago #7592 by Knoxtech
Yea I'm a little confused even after looking a waveform diagrams on google. So a period is one cycle or basically in a duty cycle "on time" plus "off time" (some one please correct me on anything this wrong). So I that's why I had had picked 50% but the. You take the 4 times pulse width I can see how you get the 25% . Still pretty confused. I assume Dylan know the correct answer and with a explanation. If you use my math of the clue from the questions I feel like the the correct answer is B 25% with 12.5 on time. Please Dylan let me know how badly I missed the " easy question".
9 years 7 months ago #7610 by Noah
Replied by Noah on topic Test question
Uuuhhhh.... What?
Lmao, so what is a period? Can you provide a sample waveform?
9 years 7 months ago #7611 by Knoxtech
here is the waveform example I was referencing. I am probably way wrong just trying to tossing out thoughts
http://www.electronics-tutorials.ws/waveforms/tim3.gif?x98918
9 years 7 months ago #7617 by SniperDan
Replied by SniperDan on topic Test question
One period is the amount of time between the start of a cycle, to the beginning of a new cycle. The answer to this question would be 25%
~W. Edwards Deming
9 years 7 months ago - 9 years 7 months ago #7618 by SniperDan
Here's one...
On a 12v solenoid that is duty cycled and ground side switched, a digital multimeter is used to measure control side voltage. The voltage reading on this circuit read 3 volts. Assuming this solenoid is duty cycled continuously, what is the duty cycle of this solenoid?
A. 75%
B. 33.33%
C. 50%
D. 25%
~W. Edwards Deming
Last edit: 9 years 7 months ago by SniperDan.
9 years 7 months ago #7621 by Knoxtech
Here goes another probably wrong answer but I would say Answer A. 3volts /12 votls = 25% but because the device is ground side switched and measured with a multi-meter the reading is the off time so you have 75% on time.
9 years 7 months ago - 9 years 7 months ago #7623 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Test question
I have come across two different ways of defining duty cycle.
This is the one that makes sense.
en.wikipedia.org/wiki/Duty_cycle
Key is current flow the percentage of the time current is flowing --- what proportion of the time the device is powered up.
Ground side switched circuits have to be considered with care. As measuring across the pins of groundside switched circuit will give a different wavefom than measuring between the control wire and chassis ground.
Last edit: 9 years 7 months ago by Andy.MacFadyen.
  • Dylan
  • Belgium, Europe
9 years 7 months ago #7627 by Dylan
Replied by Dylan on topic Test question
Knoxtech wrote: Yea I'm a little confused even after looking a waveform diagrams on google. So a period is one cycle or basically in a duty cycle "on time" plus "off time" (some one please correct me on anything this wrong). So I that's why I had had picked 50% but the. You take the 4 times pulse width I can see how you get the 25% . Still pretty confused. I assume Dylan know the correct answer and with a explanation. If you use my math of the clue from the questions I feel like the the correct answer is B 25% with 12.5 on time. Please Dylan let me know how badly I missed the " easy question".
Correct! Don't doubt yourself. Reasoning is good. Thx for answering :)
  • Dylan
  • Belgium, Europe
9 years 7 months ago #7629 by Dylan
No challenge for you SniperDan. Thx :)
  • Dylan
  • Belgium, Europe
9 years 7 months ago #7630 by Dylan
Andy.MacFadyen wrote: I have come across two different ways of defining duty cycle.
Yes. 2 periods with a 25% duty cycle
  • Dylan
  • Belgium, Europe
9 years 7 months ago - 9 years 7 months ago #7633 by Dylan
Duty cycle equation:
D=PW/T X 100%
D (Duty cycle)=Pulse width (On-time) divided by T (total period of the signal) multiplied by 100%
Boring... I know :whistle:
9 years 7 months ago #7634 by SniperDan
Never boring! ALWAYS FUN
~W. Edwards Deming
  • Dylan
  • Belgium, Europe
9 years 7 months ago - 9 years 7 months ago #7636 by Dylan
Found a video that covers the basics and explains it better than I can...
9 years 7 months ago - 9 years 7 months ago #7637 by Andy.MacFadyen
This is the the duty cycle output from a Denso alternator signal wire to the PCM.
High load on the alternator pulls the duty cycle down, normal duty cycle at idle is roughly 60% . This is the effect on the duty cycle of turning the heated rear window on.
If the alternator is loaded up using a carbon pile tester the alternator will go full field and the output amps will max out under these conditions the duty cycle will flat line at zero.
9 years 7 months ago #7646 by Tyler
Well that was fun! :lol: What else you got, Dylan?
  • Dylan
  • Belgium, Europe
9 years 7 months ago #7702 by Dylan
SniperDan wrote: Here's one...
A. 75%
B. 33.33%
C. 50%
D. 25%
Don't forget this one guys :)
9 years 7 months ago #7705 by SniperDan
I don't know about you Dylan, but I'm having way to much fun with this lol.
~W. Edwards Deming
Time to create page: 0.442 seconds
