Re:Re:Show us your homemade Test Equipment
5 years 5 months ago #48749 by Matt T
Replied by Matt T on topic Re:Show us your homemade Test Equipment
juergen.scholl wrote:
Wightscope wrote: So at 1200rpm a sound at 10Hz is going to be valvetrain as the cams rotate at half the speed of the crankshaft, or maybe an idler pulley bearing - if it is 2/3rds of the size of the crank pulley will make a noise at 13.3Hz
The frequency in your example would be 15 hertz, not 13.3.
An idler pulley that is 2/3 the effective diameter of the crank pulley will be rotating 50% faster. Crank is at 20Hz in the example so idler will be 30Hz if the noise only happens once per idler revolution. More likely to be a higher frequency bearing noise though.
The following user(s) said Thank You: juergen.scholl, Wightscope
5 years 5 months ago #48751 by juergen.scholl
Replied by juergen.scholl on topic Re:Show us your homemade Test Equipment
Your correct!
5 years 5 months ago #48752 by Matt T
juergen.scholl wrote: Your correct!
I think you could've been correct too if Wightscope hadn't tricked you into using camshaft frequency.
  • Wightscope
  • Wightscope's Avatar Topic Author
5 years 5 months ago #48753 by Wightscope
Replied by Wightscope on topic Re:Show us your homemade Test Equipment
I'll be more careful about my casual examples next time !
5 years 5 months ago #49352 by Ben
Alright got another 1 today with the chassis ear on a diesel injector and a pulse sensor in the radiator . This 1 happens to be on my poor severely overheated lawn mower.....
5 years 5 months ago #49353 by Ben
5 years 5 months ago #49354 by Ben
The sync is on injector #2 I'm not sure what degree they fire in relations to crank angle so I just marked the peak pressure and divided( I measured 180 degrees from pulse to peak but I believe this is direct inject and not above the intake valve?)
5 years 5 months ago #49355 by Ben
Setup
5 years 4 months ago #49407 by Noah
Is it stupid that I'm impressed by your commercial grade lawn mower?
Time to create page: 0.326 seconds
