Re:Re:Show us your homemade Test Equipment
5 years 6 months ago #48326 by Noah
Replied by Noah on topic Show us your homemade Test Equipment
John Curtis wrote: I’ve got a whole list of things to develop and make. So far this is it.
Those look great!
5 years 6 months ago - 5 years 6 months ago #48340 by John Curtis
Replied by John Curtis on topic Show us your homemade Test Equipment
Those look great!
Thanks. Just tuned everything in and fixed the flaws going forward that were in the initial sets. The initial sets are functional but a tiny bit out of square during production. Figured I’d make a holder for them that can double as a way to hold my test leads.
Unfortunately I’ve got about 4 sensors that aren’t perfect visually but have the same functionality.
Last edit: 5 years 6 months ago by John Curtis.
5 years 6 months ago #48360 by AJeep18
Replied by AJeep18 on topic Show us your homemade Test Equipment
[quote=
Unfortunately I’ve got about 4 sensors that aren’t perfect visually but have the same functionality.[/quote]
PM sent
5 years 6 months ago #48367 by John Curtis
AJeep18 wrote: [quote=
PM sent[/quote]
Responded.
5 years 6 months ago #48411 by Tyler
Replied by Tyler on topic Show us your homemade Test Equipment
John Curtis wrote:
But seriously, what's your PayPal?
5 years 6 months ago #48418 by John Curtis
Tyler wrote:
I’ll PM you.
5 years 6 months ago #48489 by Tyler
John Curtis wrote: I’ll PM you.
No I'll PM YOU!
5 years 6 months ago #48511 by AJeep18
Going off some of the ideas here, I decided to “mod” my test light. Added an insulated female spade terminal to the end and then male ones the the end of the attachments I wanted, I think it worked out pretty well! And no need to have 3 different test lights with different ends!
  • Wightscope
  • Wightscope's Avatar Topic Author
5 years 6 months ago #48514 by Wightscope
Replied by Wightscope on topic Show us your homemade Test Equipment
Nice !
I have been using stackable banana plugs - effectively both male and female so one on the test light one on the earth clamp and all my probes also fit so I can alligator or probe for a jumper.
Also got a 10ft double ended retractable reel that has two wires, one I put stackable bananas on each end, others are alligators.
Just made a cable today for using a phone power bank as a 5v power supply for pressure transducers, added 33ohms of resistance else the powerbank shuts off after 30s. Sadly 150ma was too much for the LED I built in to it!
5 years 6 months ago #48518 by Matt T
Replied by Matt T on topic Show us your homemade Test Equipment
Wightscope wrote: Just made a cable today for using a phone power bank as a 5v power supply for pressure transducers, added 33ohms of resistance else the powerbank shuts off after 30s. Sadly 150ma was too much for the LED I built in to it!
Good thinking about the resistor. I've had problems with both a power bank and a 18V>12V/5V power tool battery adapter shutting down at low load with my USB>Banana cable. The tool battery adapter was also shutting off the 12V with my 10-30V "transducers". Hacked it to to run 18V straight from the battery to the 12V port.
  • Wightscope
5 years 6 months ago - 5 years 6 months ago #48519 by Wightscope
For 12v stuff I bought one of those 20AHr Lithium jump starters with a 10A, 12v output on a 5mm plug.
Mainly use it via a 12/24v buck to run a Quiko soldering iron set up - that works really well -and I have a Jump starter handy as a bonus.
Most of my transducers are 5v but I just got a 10Bar absolute (ie complete vacuum to +9bar) sensor that is 12v, - going to need a load cable for that too.
Last edit: 5 years 6 months ago by Wightscope.
5 years 6 months ago #48525 by AJeep18
Beat you to it Tyler :)
5 years 6 months ago #48536 by Tyler
AJeep18 wrote: Beat you to it Tyler :)
Lookin' good. B)
5 years 6 months ago #48627 by Ben
Replied by Ben on topic Re:Show us your homemade Test Equipment
A few things I used on my scope recently and thought I would share the first using a chassis ear to visualize a bad wheel bearing (easily done with the included headphone) I'm going to try these on different places around the engine to find noises next time I get 1 ticking to see if it helps. the second is just a current shunt I was diagnosing a intermittent parasitic drain from rubbed through wire in the harness and needed to be able to see when and where I was pulling that it acted up, so like everybody else I grabbed my low current probe only to find it had been left on for the 10th time in a row and the battery was dead and I was out of 9v batteries (I assume just like everybody else) but I had a 30a current shunt laying around from a project years ago and it worked ! Not great certainly to low current probe like but good enough to find a intermittent draw while i wiggled the harness . Sorry I get any pics of it in use...
The following user(s) said Thank You: Noah, Wightscope
5 years 5 months ago #48704 by Ben
Here's another 1 on a rear wheel drive Lincoln front wheel bearing is bad sounds like it's coming from drivers on road test but load test says passenger. spinning front wheel by hand you can hear there is bearing noise from right side and just a slight rotor scrape on left side. hooked up the chassis ear and listening with headphones cannot tell which bearing is making noise (I was suprised as I could hear it without headphones) hooked it up to chassis ear and spinning left side with rotor scrape is 1st frame 2nd and 3rd is spinning right side
  • Wightscope
5 years 5 months ago - 5 years 5 months ago #48711 by Wightscope
Replied by Wightscope on topic Re:Show us your homemade Test Equipment
I have seen a clever trick with a stethoscope on an oscilloscope which is to look at the frequency peak of the sound then you can match it to the crank, valvetrain, a wheel a particular pulley or whatever.
So at 1200rpm a sound at 10Hz is going to be valvetrain as the cams rotate at half the speed of the crankshaft, or maybe an idler pulley bearing - if it is 2/3rds of the size of the crank pulley will make a noise at 13.3Hz
There must be a simple way of detecting which wheel bearing it is by seeing if the frequency goes up or down when turning a corner...
Last edit: 5 years 5 months ago by Wightscope.
5 years 5 months ago #48712 by Ben
I love the idea of using frequency to diag how fast it's moving sadly I decided to save a few bucks and bought the autel scope rather than the picoscope..... and as luck would have it they dont support frequency yet....
  • Wightscope
5 years 5 months ago #48713 by Wightscope
Replied by Wightscope on topic Re:Re:Show us your homemade Test Equipment
It's a lot of bucks difference!
My wallet is not yet recovered from the delivery yesterday of a fresh 4425A with it's fancy leads. I was indecisive about it, then a standard kit came up on ebay - 2 months old, like new for 20% off the new price, quick chat with the seller and done. It's perfect -only one of the leads had ever been out it's bag.
Still undecided about Pico 7 but I think that is just familiarity.
But yea that's a lot of time to sell, I tend to reach for the scope a lot - especially as I'm doing a few classics at the moment.
5 years 5 months ago #48714 by Ben
Nice!
5 years 5 months ago #48745 by juergen.scholl
Replied by juergen.scholl on topic Re:Show us your homemade Test Equipment
Wightscope wrote: So at 1200rpm a sound at 10Hz is going to be valvetrain as the cams rotate at half the speed of the crankshaft, or maybe an idler pulley bearing - if it is 2/3rds of the size of the crank pulley will make a noise at 13.3Hz
/quote]
The frequency in your example would be 15 hertz, not 13.3.
Time to create page: 0.379 seconds
