Rotkee vs. Pico
5 years 7 months ago - 5 years 7 months ago #47502 by cadman777
Replied by cadman777 on topic Rotkee vs. Pico
Guys,
Thanx for all this very informative input.
Thanx also for the links to further info.
I looked at the ATS before, but like you say, it's too expensive.
My main concern is learning how to read the graphs, esp. the stacked graphs.
Does anybody know of any educational stuff on that that I can use at my own snail's pace?
Here's an example of one little piece of a larger educational series:
Thanx...
Last edit: 5 years 7 months ago by cadman777.
5 years 7 months ago #47510 by stevieturbo
Replied by stevieturbo on topic Rotkee vs. Pico
A post just now from Instagram.
"rotkee Unfortunately, our suppliers failed to deliver the key components in time. As a result, we have to stop manufacturing our produce until further notice.
We are currently in search of new suppliers and alternatives for understocked components. This is the reason we don’t have time to answer all the questions we receive via email and messengers. All paid orders are to be delivered by 20 March. As for pending orders, we’ll first check if all the items are available at the warehouse and then let you know about the tentative delivery date.
We apologize for any inconvenience caused."
5 years 7 months ago #47569 by stevieturbo
I guess no need for concern, mine arrived today. All good.
Connected up via LAN to home PC, and have run a couple of waveforms through it from my simulator.
Can clearly see 36-1 hall trigger at 9000rpm, 720 timing markers with compression/firing cycles already marked up etc.
I guess it'll take a while to figure more out. Haven't tried to connect via WiFi yet via a router though to see if that will work ok. Would need the laptop to test that
The following user(s) said Thank You: Wightscope
5 years 7 months ago #47570 by Wightscope
Replied by Wightscope on topic Rotkee vs. Pico
Pics please !!
5 years 7 months ago - 5 years 7 months ago #47572 by stevieturbo
This is a test of crank cam from a simulator...I had thought initially it was 9000rpm, but it's actually 16,000rpm. So still a good clean waveform at that, 36-1 with a single tooth cam.
File Attachment:
File Attachment:
File Attachment:
And the selection of stuff. Have to say the quality seems very good, even the moulded rubber parts of some connectors have Rotkee embdedded in them. A more distinct +/- marking at those specific banana sockets would be nice, but it is printed. A dab of paint will sort it though.
But as others said, the shielded banana plugs are nice, and in general quality seems good, especially considering the low cost.
Must admit...the connectors I ordered with a single BNC, but either 3 or 4 terminals ( like this pictured with two pairs ), haven't a clue what they're for. I guess they're just splitting for measurement of two things at same plug, that occur at different times. Either way, quality of them is good.
File Attachment:
Last edit: 5 years 7 months ago by stevieturbo.
The following user(s) said Thank You: cadman777, Wightscope
5 years 7 months ago #47575 by Wightscope
Wow you did buy the full kit ! Thanks for the pics.
The software looks very clean, interested to hear what you think after a bit of use.
5 years 7 months ago #47596 by stevieturbo
I certainly didn't buy the full...but did buy a selection from what they had in stock.
I already have some other parts anyway. So far no joy with the wireless aspect though.
All in less than £500...doesnt seem bad at all when even the cheaper EU/US/UK stuff want that for the scope alone.
5 years 7 months ago - 5 years 7 months ago #47830 by stevieturbo
No eBay APP ID and/or Cert ID defined in Kunena configurationSo far, have tested it on a few things ( no cars though ), just messing about. Software doesn't seem too bad really.
I did buy a large cheap current clamp off ebay and as I didn't have anything high current handy in the garage...decided to try measuring me TIG welding lol.
I have a little Hantek clamp, but it's the small jaw version. So I bought this. At only £29 seemed rude not to. It feels pretty good quality, albeit with banana plugs, no BNC. No big deal though
Seems the forum doesn't like ebay links....but it was ISO-TECH ICA39T 1000A AC/DC CURRENT TRANSDUCER.
However, the MTPro wasnt happy and threw errors every time I struck an arc to weld. Don't know why, will send the error message to Rotkee and ask.
I tried scoping current and voltage of a little battery tester that performs a discharge test on small 6/12v batteries as I wanted to see what it was doing.
In the time of around 60ms it performs multiple load tests on the battery ( this one was deemed flat though, small 12v 7Ah battery ) even though no load it registers 12.38v
File Attachment:
I did try scoping the live cable of a heat gun as an ac current test. That didn't seem to perform ok, with it fluctuating around -16A under load, and even with the power turned off at the plug, it still seemed to cycle around 50hz so clamp must be picking up something.
Not sure how to zero it....must read instructions I guess
File Attachment:
I bought the little pulse sensor thingy for the likes of diesel pipes, so will hopefully get to try that in a couple of weeks on some old generators in work to see if it actually gives a usable signal of an injector firing etc.
5 years 7 months ago #47833 by Tyler
Replied by Tyler on topic Rotkee vs. Pico
I have no idea why, but mine just now shipped. :unsure: :angry: Really wish I'd have ordered more test equipment like stevieturbo did...
5 years 5 months ago #48726 by Tyler
For whatever it's worth to anyone following along, I did eventually get my MTPro back in April. :silly: Getting the payment to process was the hardest (longest) part. I don't know of a more straightforward way to do this if you live in the US.
Purely as a scope, it's pretty fantastic. The MTPro software calls it 'Working Space'. The options for displaying and manipulating the various channels seems endless. :silly: It's definitely a different experience from the Pico software, so it takes some getting used to.
The automated testing functions are a little bit harder. With no English instructions on how to set up the tests, it's a game of trial and error to get them working correctly. The 'El.Power circuits' test, for example:
These are the results you get from completing the test. Cool stuff! I can sell service with this. BUT, what you don't know is the sequence to get you here. Battery below 12.6V, start the engine, idle for more than five seconds, raise the RPM, add loads, idle down. That all sounds pretty standard for starting/charging system testing, but you don't know how the software wants it. :silly: Getting to these results probably took seven or eight tries, and I STILL didn't get it quite right.
The intake pulse test is more straightforward, but still a bit fiddly:
The hardest part is making the ignition sync work. I didn't order an Lx1 Inductive Sensor , which is probably what they want you to be using. :lol: So I tried several of my homebrew secondary probes. Ended up backprobing the coil signal wire, and it still wasn't completely happy with that.
I'll keep playing with it when I get time!
5 years 5 months ago #48728 by stevieturbo
I did buy a selection of the inductive sensors, but haven't got around to using them yet.
The pre-configured accessories is pretty decent, although when doing a custom one, it needs a really really tiny image of it lol
5 years 5 months ago #48737 by vb4me
Replied by vb4me on topic Rotkee vs. Pico
Has anyone else had this message.
Haven't been able to try mine out yet.
5 years 5 months ago #48738 by stevieturbo
Is that not the error you get when it is not plugged in and powered up ?
5 years 5 months ago #48739 by vb4me
I can open up the software but when I plug in the scope this is the message that pops up.
5 years 5 months ago #48740 by stevieturbo
are you plugging the scope in and powering it up before opening the software, or after ?
needs to be powered up etc before.
Does the LAN led bit light up at the rear when powered on ?
5 years 5 months ago - 5 years 5 months ago #48743 by juergen.scholl
Replied by juergen.scholl on topic Rotkee vs. Pico
Tyler wrote: For whatever it's worth to anyone following along, I did eventually get my MTPro back in April. :silly: Getting the payment to process was the hardest (longest) part. I don't know of a more straightforward way to do this if you live in the US.
The automated testing functions are a little bit harder. With no English instructions on how to set up the tests, it's a game of trial and error to get them working correctly. The 'El.Power circuits' test, for example.
Tyler,
The only scope that is authorized to use the automated tests/scripts like the El-power, CSS and P-x test is the USB-Autoscope. Andrey Shulgin ,the author of those scripts, decided to make the latest versions/algorithms for the El-power script available available only via internet connection on a dedicated server.
You'll find detailed information about the test procedures in English on the autoscope website, pm me if necessary.
usbautoscope.eu/es/diagnostics/elpower-script/
On their you-tube channel you'll find instructive videos on how to perform all of those tests as well.
Last edit: 5 years 5 months ago by juergen.scholl.
The following user(s) said Thank You: Tyler, racer55
5 years 5 months ago #48744 by stevieturbo
It's a pity that other scope companies could not come to an arrangement with Andrey to use them legally.
Or even end users pay some sort of fee up front for access.
but it does seem to confirm that the MTPro should not be using them.
5 years 5 months ago - 5 years 5 months ago #48746 by juergen.scholl
vb4me wrote: I can open up the software but when I plug in the scope this is the message that pops up.
Quite some possible causes, from a broken usb cable to a bad unit.....
Supposing you installed the drivers correctly: Is the scope recognized by the windows device manager?
5 years 5 months ago #48748 by stevieturbo
There are no drivers as such. It's LAN based.
And the USB plug only provides 5v power to the unit, hence asking of there are any lights on the rear that indicate it has power.
5 years 5 months ago - 5 years 5 months ago #48763 by vb4me
stevieturbo I have 5v at the connector. No lights on rear of unit. unplugging then reinserting the plug results in a yellow and a green LED lighting up briefly then going out. Sounding like a faulty unit?
It does this with the LAN cable plugged in or out.
Last edit: 5 years 5 months ago by vb4me. Reason: extra info
Time to create page: 0.432 seconds
