Rotkee vs. Pico
5 years 8 months ago #47069 by stevieturbo
Replied by stevieturbo on topic Rotkee vs. Pico
I basically ordered one or two of most of the stuff he had in stock.
I figured why not, it's all fairly cheap, so may as well do it in one postage. Even if things don't work out, the accessories should work with any scope anyway.
I already have a Ditex pulse sensor and Hantek clamp along with various other bits n bobs. Just the old scope I had is pretty useless and never really worked since I changed laptops.
I'll be trying this MTPro with a wireless router for wireless connectivity, although in 5G mode that would see a max of around 500Mbps...whether that will be a problem or not I don't know. But it's easy to run a LAN cable too. I would just like it to be wireless.
5 years 8 months ago - 5 years 8 months ago #47089 by cadman777
Replied by cadman777 on topic Rotkee vs. Pico
I just made my own 'pulse sensor' (differential pressure sensor).
Used it yesterday on both Exhaust Gasses and Manifold Vacuum.
The signals looks excellent based on what I've seen others get from expensive pressure transducers.
Granted, it's not a pressure measurement, but it's a signal that can certainly be used to diagnose.
After making this probe and a simple COP probe, I'm inclined to make all my own pickup devices, unless it's impossible or inconvenient or ROI ineffective.
The cost of this recent sensor was about $8US.
The money went to three PVC pipe fittings @ 1-1/2" nominal and a NTPM barbed nipple (from HomeDespot) and a BNC/BananaClip cable (from fleaBay).
The rest of the stuff I had (glue & hose).
I got my idea off YT from 'the forklift mechanic'.
Only thing I did wrong was connect the wires backwards (black/black & red/red).
Should've checked the signal before soldering and shrink-wrapping.
Too late to re-do!
Currently I'm looking at the USB scope vs the Rotkee.
Not sure the differences.
Maybe the software is what sets them apart?
All I care about is being able to 'hook-up', get signals, and process the signals in an interpreter so I can analyze them for ANYTHING and EVERYTHING that may be wrong with the engine or controls system.
I want a ONE SIZE FITS ALL approach to ANY vehicle.
The Ruskies seem to have figured it out.
Too bad Americans have failed to.
Just goes to show how 'evil commerce' in America has locked-down control over everybody's freedom to innovate!
KISS: Keep it simple stupid.
Last edit: 5 years 8 months ago by cadman777.
5 years 8 months ago #47098 by stevieturbo
I think the USB does have slightly better resolution, and the software does look a little easier....perhaps more from an English point of view.
And there are a lot more help videos on Youtube.
USB also seems to use XLR fittings, so they are dedicated to that unit, but as such seem to easily be able to derive power from the unit as needed instead of needing separate power.
But for the likes of CAN work...I do not believe either of these have adequate bandwidth for good diagnosis, nor do they decode the data.
But for basic stuff...seems all good. Hopefully for a learning platform they'll be all good.
It's just a pity neither of them have easier routes of purchase
The following user(s) said Thank You: cadman777
5 years 8 months ago - 5 years 8 months ago #47120 by cadman777
Good to know.
XLR fittings are on my ancient DRB II.
I like them b/c they're substantial.
But all of my current scope fittings are BNC.
So that makes my existing inputs useless to a USB scope.
But it's like you say, there's Pros/Cons for either scope.
Began watching some of the 'dubbed' videos.
Very good job so far.
But I'm waiting to see if I learn something new.
Too bad nobody's done a comparison between the USB & Rotkee scopes.
If I was an 'expert', I'd do it myself!
5 years 8 months ago #47121 by stevieturbo
As said, reading some forums, some seem to imply the Diamag and Rotkee/MTPro are copies of the USB and there were some questions raised as to the use of Andrey Shulgins scripts.
But they do seem to be available on all platforms.
It wouldn't be too hard to knock up a few leads from XLR to BNC anyway if you did go down that route.
On a price point, Rotkee is very good, even if it is not fantastic spec. As said, I like the LAN aspect....which also means easy WiFi connectivity hopefully.
Plus it seems to say all inputs are +/- 300v....which means rarely would an attenuator be needed. Maybe a moot point...maybe a downside ? who knows.
Looking forward to it anyway. Also just got a little signal generator/simulator for various crank/cam triggers and a few 0-5v analogue. I'll use it to make up a little test box to play with the scope. ( truth be told... already broke it by setting the PCB down onto a bit of metal...but should be an easy fix as it's arduino based lol )
5 years 8 months ago - 5 years 8 months ago #47133 by cadman777
Yes, it's no big deal going XLR to BNC, but I want as few connections as possible in the lines.
I've got a BK Precision signal generator I can use to actuate 'things', but not too sure how to use it yet on the vehicle. I read somewhere the older PicoScopes had a signal generator to give you bi-directional control over the vehicle's actuators. But like I said, I don't know when or how to use it in conjunction w/the scope.
Huge learning curve for an old time mechanical guy like me!
5 years 8 months ago #47135 by stevieturbo
A device that actuates things, is not necessarily a signal generator. It could be a simple off/on switch. Which isn't quite the same thing.
And any build in signal generators from a scope, would never provide enough current for any actuators, unless the power supply for the actuator was independent from a control circuit.
5 years 8 months ago #47162 by cadman777
What I'm looking for is a way to control the devices in the electronic circuit using a simple computer with interface.
I realize I can spend a few 1000 on a Snapon scanner (money I don't have to spend) and get that, for the most part.
I also realize I can 'subscribe' to the OEM provider and get that functionality for a fee (about 1500 bux for each make's VCI - more coins not in my pocket).
So, I was figuring there's gotta be a simpler and cheaper way to operate the controls from a computer using something else.
For example: when you want to do an injector balance test, or when you want to range an IAC, or when you want to turn off a COP, or something like that.
That's what I was wondering if I could use my BK Precision signal generator to do.
But even if I knew how to do that, I wouldn't know how to do it with the engine running and in conjunction with the functions of the ECU/PCM or any other system.
See what I mean?
5 years 8 months ago #47167 by stevieturbo
cadman777 wrote: What I'm looking for is a way to control the devices in the electronic circuit using a simple computer with interface.
See what I mean?
Yea, some OEM ecu's with the correct tool, will allow you to activate various devices....but a lot will not. Aftermarket scan tools....again, some will some wont. Very few if any allow the user full control over every single actuator though for testing.
Of course the other option to actuate such items...is run the engine. At least then, the correct ecu, will be operating them as that manufatcurer intended.
Or to feed the ecu a simulated crank/cam trigger so it does operate all devices as normal...just without the engine running. Taking precautions about filling the engine with fuel via the injectors of course.
But that doesn't allow you to operate one item at a time as such.
But there are crank/cam simulators out there, and I've one sitting here on my bench right now made from an arduino nano, which itself is designed for people to test their "speeduino" engine control unit, which is a basic ecu made from an arduino.
You feed it a crank signal, and then you can monitor it's behaviours and check various outputs are operating. And in that case, you could hook it up to injectors, coils etc if you wanted.
There are a lot of novel things that go on in separate worlds...more of them should combine as it could be mutually beneficial.
5 years 8 months ago #47172 by cadman777
That SPEEDUINO looks interesting!
It just may be an answer to some other things I've been thinking about.
5 years 8 months ago - 5 years 8 months ago #47173 by stevieturbo
Speeduino itself is a DIY project....and ultimately is a full engine control ecu.
the Ardustim I mentioned is another project to aid testing of the speeduino, which is code that uses a nano to create crank/cam patterns.
I actually got mine working there tonight, although first test generates a square wave signal ok. Not sure if it is able to generate a simulated VR signal though.
Last edit: 5 years 8 months ago by stevieturbo.
5 years 8 months ago #47204 by diamond84
Replied by diamond84 on topic Rotkee vs. Pico
I've got the rotkee scope in the uk and most of their attachments, i must say, its pretty good. the leads are good quality. software took some time to get use to, but had very good advanced features.
5 years 8 months ago #47211 by stevieturbo
Would it be worth a new thread exclusively to the workings of it ?
Have you found any obvious limitations ?
5 years 8 months ago #47232 by Tyler
Replied by Tyler on topic Rotkee vs. Pico
Finally got my scope ordered. :woohoo:
5 years 8 months ago #47242 by diamond84
It blows my old hantek out the water, still getting used to all the functions. im still learning scope diagnosis. rotkee have a library too.
5 years 8 months ago #47243 by Tutti57
Replied by Tutti57 on topic Re:Rotkee vs. Pico
Hmm, I was checking out their site last night. Accessories are very inexpensive too, unless I missed some monetary conversion button.
5 years 8 months ago #47244 by stevieturbo
Replied by stevieturbo on topic Re:Rotkee vs. Pico
Yep, all quite cheap.
Although I guess it's relative. We see cheap.....or is it everywhere else is overpriced ?
Still no further communication from them, other than an email 10 days or so to confirm payment received.
Must email them to see if it has shipped yet.
5 years 8 months ago #47246 by Wightscope
Replied by Wightscope on topic Re:Rotkee vs. Pico
I did get an email to say my few parts had shipped a few days after payment.
5 years 7 months ago #47315 by AJeep18
Replied by AJeep18 on topic Re:Rotkee vs. Pico
I ordered some 6ft Banana back probing leads a couple of weeks ago and got them in the mail today. Seem ok. The wire is speaker cable though... no too impressed by that. I like that the tips are flexible. Eagerly awaiting your review of the scope Tyler!
5 years 7 months ago - 5 years 7 months ago #47316 by AJeep18
Here is what the look like [attachment=9086]
Last edit: 5 years 7 months ago by AJeep18. Reason: double posted pictures
Time to create page: 0.416 seconds
