DIY Pressure Transducer
  • Charles Acosta
  • Charles Acosta's Avatar Topic Author
8 years 7 months ago #19517 by Charles Acosta
DIY Pressure Transducer was created by Charles Acosta
Built my own kit with 100 and 300 psi transducer. To test the 100 psi I set the compressor air to 50 psi. With the rubber tip nozzle I pressed it against the sensor and hit the trigger. it read 49.8 psi. Next was the 300 psi doing a in cylinder running compression on a 2014 Elantra. I noticed on the capture that on the exhaust stroke its not quite on 0 psi as I've seen on other captures from online. I customize my probe 0v = -37.5 psi, 0.1 = 0 psi and 4.5v = 300 psi. Maybe the settings need to be tweaked more? You guys can chime in. Last but not least bought the storage box from Harbor Freight with a their 25% off coupon. Happy Easter everyone.
The following user(s) said Thank You: Noah, Dylan
8 years 7 months ago #19538 by Noah
Replied by Noah on topic DIY Pressure Transducer
Very cool, nice work B)
The following user(s) said Thank You: Charles Acosta
  • Ro-longo
  • Ro-longo's Avatar
  • North Salt Lake, Utah
8 years 7 months ago #19639 by Ro-longo
Replied by Ro-longo on topic DIY Pressure Transducer
Where did you get the transducers from?
  • Charles Acosta
8 years 7 months ago #19645 by Charles Acosta
Replied by Charles Acosta on topic DIY Pressure Transducer
From eBay
  • Ro-longo
  • Ro-longo's Avatar
8 years 7 months ago #19649 by Ro-longo
Charles Acosta wrote: From eBay
Do you have a link? I purchased a 300 psi transducer from ebay awhile ago and it didn't work as expected.
  • Charles Acosta
8 years 7 months ago - 8 years 7 months ago #19658 by Charles Acosta
[ebayhttps://www.ebay.com/itm/USA-New-Pressure-Transducer-or-Sender-Stainless-Steel-for-oil-fuel-air-water/253238407682?ssPageName=STRK%3AMEBIDX%3AIT&var=552357600573&_trksid=p2060353.m1438.l2649
Last edit: 8 years 7 months ago by Charles Acosta.
The following user(s) said Thank You: Noah, Ro-longo
  • Ro-longo
  • Ro-longo's Avatar
8 years 7 months ago #19661 by Ro-longo
No eBay APP ID and/or Cert ID defined in Kunena configuration
Charles Acosta wrote: [ebayhttps://www.ebay.com/itm/USA-New-Pressure-Transducer-or-Sender-Stainless-Steel-for-oil-fuel-air-water/253238407682?ssPageName=STRK%3AMEBIDX%3AIT&var=552357600573&_trksid=p2060353.m1438.l2649
Your link didn't work, I fixed it though, Thanks!!
8 years 6 months ago #19681 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic DIY Pressure Transducer
Nicely done, it is a really good feeling when you get your successful in-cylinder waveform with a home build sensor.
  • Charles Acosta
8 years 6 months ago #19685 by Charles Acosta
You welcome
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
8 years 6 months ago #19709 by Dylan
Replied by Dylan on topic DIY Pressure Transducer
Missed this one :(
I'm impressed. Nice work and a LOT cheaper than a WPS500 :)
8 years 6 months ago #20184 by SailorBob
Replied by SailorBob on topic DIY Pressure Transducer
I just built my own transducer also, but took a slightly different approach. I used a Drok 2203 buck converter which takes between 22-8vdc input and outputs steady 5vdc. I could just carry around a 9v battery and connect it, but I'm cheap so I want to just use the car battery as my power source.
The problem I've run into is that AC from the alternator is being passed through and making my waveforms hard to read:
So I was thinking about taking a 0.1uF capacitor and hooking it across the transducer signal wire and ground to shunt the AC component to ground and clean up the signal, but I'm no electronics engineer and was wondering if someone here might know if that'll work.
8 years 6 months ago #20185 by SailorBob
By the way, here are some nice online transducer training materials:
Just scroll down to the middle of the page:
www.picoauto.com/library/training
Example captures of various types of problems:
www.automotivetestsolutions.com/pressure...en-shots-page-1.html
  • Charles Acosta
8 years 6 months ago #20198 by Charles Acosta
You may have to go the 9 volt battery route to see if you get a cleaner signal. If you do buy a pack of 9 volt batteries.
8 years 6 months ago #20199 by SailorBob
After some testing, I discovered that it is the transducer itself generating that 40mv, 1 kHz sine wave noise:
I might try the transducer the OP bought and see if I have better luck.
8 years 6 months ago #20209 by SailorBob
After experimenting with various capacitor sizes I have laying around, I found the best results came from a 0.1uF mylar cap between the signal wire and 0V ref. It reduced the amplitude of the sine wave by almost 50%. Couldn't get anything better than that. However, I think the real problem is just that these transducers are cheap Chinese junk.
  • Charles Acosta
8 years 6 months ago #20226 by Charles Acosta
SailorBob wrote: After experimenting with various capacitor sizes I have laying around, I found the best results came from a 0.1uF mylar cap between the signal wire and 0V ref. It reduced the amplitude of the sine wave by almost 50%. Couldn't get anything better than that. However, I think the real problem is just that these transducers are cheap Chinese junk.
Use the link I posted earlier. They cost me 20 bucks and it turned out well. With the Pico it zeroes nicely.
It also works with the Verus but it is not zeroed. You could still do the numbers
8 years 6 months ago #20237 by SailorBob
No eBay APP ID and/or Cert ID defined in Kunena configurationIt turns out that there were two problems. The buck converter was generating a 400 kHz 40mv sine wave on it's power output, and the transducer itself was also generating a bunch of noise. I was able to clean up the converters output with an RC low pass filter I made from a 47 ohms resistor and a 1uF cap.
As far as getting a new transducer, the one you used doesn't ship to Israel, but I found this other one that looks pretty good, I'm getting a -14.5-30 psi and 300 psi.
If you're interested in the LFP, you can see more about it here:
electronics.stackexchange.com/q/370804/149212
8 years 6 months ago #20238 by SailorBob
not sure why the ebay link isn't showing up....
8 years 6 months ago #20305 by SailorBob
here's the final fix. I was able to clean up the signal on the 200 psi transducer enough that it's useful for work:
  • Charles Acosta
8 years 6 months ago #20361 by Charles Acosta
SailorBob wrote: here's the final fix. I was able to clean up the signal on the 200 psi transducer enough that it's useful for work:
Can you do a cranking or running waveform?
Time to create page: 0.373 seconds
