Can't think through the math and know I'm right.
  • Harrison3267
  • Harrison3267's Avatar Topic Author
9 years 5 months ago #9799 by Harrison3267
Not sure how to do the conversion.
I'm using an amp clamp to gauge the amp draw on a starter. Can anyone explain both of the settings on my clamp as to what they would be per volt. Pictures below included.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 5 months ago - 9 years 5 months ago #9806 by Dylan
1mV conversion to volts = 1mV x 1000= 1000mV or 1 volt
For the 10mA scale: 10mA x 1000= 10.000mA or 10 A
For the 100mA scale 100mA x1000= 100.000mA or 100A
1mV/10mA = 1V/10A
1mV/100mA= 1V/100A (your clamp has a max input of 60amps)
1 mV/10 mA (100 mV = 1 A)
—> use this for testing currents up to 20 A.
1 mV/100 mA (10 mV = 1 A)
—> use this for testing current up to 60 A.
Make sense?
So you'll need to use a high amp clamp to measure starter current... ;)
Last edit: 9 years 5 months ago by Dylan.
9 years 5 months ago #9818 by Tyler
Dylan has the math right for that clamp. It looks like the peak current seen during the start of your capture is about 2V, with translates to around 200A. The clamp is rated to 60A, but I've found most low amp probes are actually capable of measuring much higher. I use that same style of clamp for relative compression stuff all the time.
For comparison, here's a waveform I took off a 2.4L Honda with a failing starter. Yellow is battery voltage, green is starter current.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 5 months ago - 9 years 5 months ago #9822 by Dylan
Oh yeah definitely! Me too. I also tried to AC Couple cause I saw the guy from realfixesrealfast doing this :)
9 years 5 months ago #9825 by Noah
I just un-stickied (is that a word?) the amp clamp voltage conversion charts that Andy posted too...
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 5 months ago #9829 by Dylan
Here are some videos you might wanna take a look at.
Feel free to ask any question you have.
9 years 5 months ago #9842 by jimdandy327
Replied by jimdandy327 on topic Can't think through the math and know I'm right.
Wow I hope this dose not post twice but her it is again. I have that same Amp Clamp and a Snap On Verus. I found out that if you set the scope to the 20 amp scale that that amp clamp reads right on the 10ma setting. I compeared it to my bosses Snap on amp clamp at the 20 amp setting it is the same.
9 years 5 months ago - 9 years 5 months ago #9846 by Noah
I use an Innova 3347.
When set on 10mv/1A, it is accurate on the Verus low amps 60 setting.
I like to write stuff like that right on the tool, my Verus has similar notes on it...
Last edit: 9 years 5 months ago by Noah.
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 5 months ago #9848 by Dylan
What is the maximum amperage you guys can read with the low amp probe? Just wondering.... We can see a 2V=200A in the first post here.
9 years 5 months ago #9851 by Noah
Well, just thinking out loud here, but you could theorize that the maximum amperage displayed would be determined by the voltage available to the "magic box" in the amp clamp.
We know the source voltage is 9v, it's probably stepped down to a slightly lower voltage so as to not so severely impact measurements as battery life decays. So if the "magic box" was fed a regulated 6v, close to 6v would probably be the clamps maximum output.
So, 600ish amps??
Again, that's all just B.S.
I can try it on my Caterpillar
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 5 months ago #9973 by Dylan
Well I found an older post here in this section.
scannerdanner.com/forum/diagnostic-tools...amp-max-current.html
Seems that the Snap on low amp flatlines around 250A
9 years 5 months ago #9981 by Noah
Dylan wrote: Well I found an older post here in this section.
Yeah, that's all I could get out of my Innova on the starter of the Cat front end loader. So much for my hypothesis!
I do want to put it on a wire and directly short that wire across a battery. That should max her out...
9 years 5 months ago #9983 by Tyler
Noah wrote: I do want to put it on a wire and directly short that wire across a battery. That should max her out...
:lol: Be sure to bring the makings for smores, 'cause it's gonna get toasty!
  • Dylan
  • Dylan's Avatar
  • Belgium, Europe
9 years 5 months ago #10003 by Dylan
Guys, just use a high amp clamp for measuring starter current :lol:
9 years 5 months ago #10023 by Tyler
Dylan wrote: Guys, just use a high amp clamp for measuring starter current :lol:
Nooooooooooo, that'd be to easy! We have a compulsion to misuse our tools. :lol:
