Pico Amp Clamp Max Current
  • Gregwendling
  • Gregwendling's Avatar Topic Author
9 years 11 months ago #3715 by Gregwendling
Pico Amp Clamp Max Current was created by Gregwendling
Hello,
I ran into the same problem as Scannerdanner on the Mini Cooper using the Snap On low amp probe maxing out at about 250 amps. I wanted to see if anyone knew if the Pico TA189 30 amp precision probe would go any higher before flat lining?
I'm using a Snap On Verus Edge, so I'm just doing the math to convert mv to amps. I know Pico has a clamp rated up to 2000 amps, but I could use the precision probe more due to doing parasitic draws on Euro cars.
Thanks for the input.
Time to create page: 0.253 seconds
