Chapter 2.
  • nilsson
  • nilsson's Avatar Topic Author
4 years 8 months ago #55103 by nilsson
Chapter 2. was created by nilsson
Page 24
So the ECU pull upp the igniter? The igniter than interupt the current flow from the primary windings in the coil, and generate a spark? When you power feed the igniter with the test-light, will not the light use the voltage, leaving almost zero volt to the pin of the igniter?
Page 25
The GM 3 wire sensor have a Power wire, that are feeded witht 12v for the sensor to work, a signal wire that are feeded with 5v, and ground?
The 5v feeded from PCM are pulled down to create a frequensy-signal, or?
Page26
The Gm 3300 dual crank sensor in the example get bad when hot?
Thanks and best regards Anders Nilsson
