Drop testing
  • River_NDN
  • River_NDN's Avatar Topic Author
4 years 11 months ago #53230 by River_NDN
Drop testing was created by River_NDN
Hello,
My name is Nick and I am wondering if the drop test can also be performed on a distributor engine?
Thanks for taking the time to teach me this valuable info
Nick
4 years 11 months ago #53237 by Noah
Replied by Noah on topic Drop testing
Are you referring to the RPM drop test to pick out which cylinder is misfiring?
Absolutely it can be used on a distributer engine! Disconnect a spark plug wire one at a time with the engine running and see which one doesn't effect the engine operation.
Any cylinder you disconnect that doesn't result in a drop in RPM is not contributing.
Obviously however if you disconnect the ignition coil plug wire feeding the distributer cap, the engine will stall.
Sometimes I find it hard to tell on V8 engines if there is a change in RPM, so I'll leave a cylinder disconnected (with a ground path for the spark, like a spark tester or something so as not to hurt the ignition coil) while I check the rest of them.
Time to create page: 0.266 seconds
