Chapter One_Internal Vacuum Leaks
- JChanz!!
5 years 5 months ago #49498
by JChanz!!
Chapter One_Internal Vacuum Leaks was created by JChanz!!
The book is saying "V" type engines only. Can an internal vacuum leak be found on a 4cyl engine as well?
- Thank you received: 1142
5 years 5 months ago #49511
Replied by Noah on topic Chapter One_Internal Vacuum Leaks
An inline engine is not going to have that problem. Internal vacuum leaks would be on a V engine where the crank case is exposed through the valley. Like an old small block, if you pull the lower the intake, you can see the cam. The lower intake seals that portion of the engine, so if a gasket were to leak on the inside, vacuum would leak into crack case. (Internal vacuum leak) Modern V engines aren't generally designed like that anymore, with the plenum bolting directly to the heads and a sealed valley, so that kind of internal vacuum leak isn't seen very much anymore.
- JChanz!!
5 years 5 months ago #49559
by JChanz!!
Replied by JChanz!! on topic Chapter One_Internal Vacuum Leaks
Thank you for the detailed response, very helpful
