Circuit design (page 28) and Fuel trims example (page 100)
  • guafa
  • guafa's Avatar Topic Author
6 years 3 months ago #42188 by guafa
Good day Mr Danner,
I am reviewing the book and looking for some details maybe i missed in my first read. My questions until now.
1. Page 28 (circuit design) you suggested the use of a test light to "inject" a voltage on the "GM reference wire" in order to make pcm reacts to that signal. The power to the test light comes from battery (+) lead, which is 12v.
Some systems as you mentioned also, use a 5v signal. Do you think is safe to used the test light in those cases or better to use a resistor in series with the test light to get 5v instead?
2. Page 100 (fuel trim example) you simulated a vacuum leak in bank 2 which "force" IAC to fully closed (0 step) and pcm to adjust fuel trims.
Knowing that both bank intake passages are connected, why do you think bank 1 fuel trims didn“t change? i mean, why this vacuum leak in bank 2 is not affecting bank 1 vacuum?
Thanks in advance
Time to create page: 0.379 seconds
