hummer intake valve looking at map sensor wave form
- carl
8 years 11 months ago #16139
by carl
hummer intake valve looking at map sensor wave form was created by carl
i believe what your were looking at was an event where upon every cylinder you were seeing valve overlap from other cylinders. if you count the spikes on each cylinder hump you will see increase in vaccuum cause by contribution of each cylinder because they all share intake. remember more than one intake valve is open at the same time. there is 5 distint humps going down on each cylinder event so if you are looking at number 5 cylindr you can count downward and see when each of the 5 intake valves start contributing.
- carl
8 years 11 months ago #16140
by carl
Replied by carl on topic hummer intake valve looking at map sensor wave form
I believe you are looking at intake and exhaust valve event common to the intake opening event due to overlap.
- Dylan
- Belgium, Europe
- Thank you received: 327
8 years 10 months ago - 8 years 10 months ago #16143
by Dylan
Replied by Dylan on topic hummer intake valve looking at map sensor wave form
You're talking about the Hummer H3 series right?
This is part 6 to follow along for everyone else:
Definitely check out the other parts on the free channel!
www.youtube.com/playlist?list=PLAFYVCyen...vkbvE6avGuLJOQnFcx4Z
Last edit: 8 years 10 months ago by Dylan.
The following user(s) said Thank You: carl
