Great new videos Paul. Interesting about the Keep Alive Memory. I recently worked on a Jaguar X Type 2.5 which uses a derivative of the Ford Duratec engine. The issue with the car was an ABS sensor fault which was putting on the ABS light and also a check engine light as the sensor doubles up as a speed sensor for the PCM. Once fixed, the ABS light went out ok, but I couldn't turn off the check engine light and the speed sensor code wouldn't go away. I was however able to clear the code and the light using the generic OBD2 mode of my Autel scan tool rather than the Jaguar mode. Wonder if OBD2 mode automatically resets Keep Alive Memory when used to clear codes?
Last edit: 9 years 1 month ago by Kluka. Reason: Typos in post
