test light mili-amps
  • AllaireAuto
  • AllaireAuto's Avatar Topic Author
2 years 7 months ago - 2 years 6 months ago #65464 by AllaireAuto
test light mili-amps was created by AllaireAuto
I'm finishing up your course / work book and let me say your principals need to be universally taught in all automotive training courses. ( this coming from a one time ASE master tech L-1 )
Regarding test light testing..brilliant !!..however as the course progresses there are various mili-amp draw values quoted for different types of circuits, eg; transistor, coil drivers, injector drivers ect. it would be nice to have a chart where all of this is listed to refer to when needed for doing bypass testing. I have several test lights with varying miliamp draw, this would allow using the appropriate light without doing circuit damage.  Regarding using the multimeter diode function for circuit integrity...again brilliant !...a side note about the Fluke 88V automotive meter, it generates a 7+ volt diode signal..
Last edit: 2 years 6 months ago by AllaireAuto. Reason: Clarification
2 years 7 months ago - 2 years 7 months ago #65471 by rockp2
Replied by rockp2 on topic test light mili-amps
P/V=I
Ex: 3 watt bulb ÷ 12v = .25A (250 milliamps)
Last edit: 2 years 7 months ago by rockp2.
The following user(s) said Thank You: Noah, Lupe
