2012 Acura MDX problems
4 years 4 months ago #56550 by JoseG
2012 Acura MDX problems was created by JoseG
Having problems with this SUV, it show code random misfire number 2 and 3 cylinders, I change the sparks plugs on all cylinders and ignition coils and changed the 1, 2 and 3 fuel injectors. Took it to the dealer and the mechanic said to replace rear cat and replace the EGR valve and cleaned the intake, so I did and still no luck, I did a relearn and still random misfire P0300, P0302 and P0303. What can it be??
4 years 4 months ago #56564 by Noah
Replied by Noah on topic 2012 Acura MDX problems
You may want to think about performing a compression test before going much deeper
4 years 4 months ago - 4 years 4 months ago #56573 by Tyler
Replied by Tyler on topic 2012 Acura MDX problems
What this guy said. Or a relative compression if you have the ability. Verify mechanical integrity before going further.
Last edit: 4 years 4 months ago by Tyler. Reason: stupid quotes
4 years 4 months ago #56651 by JoseG
Replied by JoseG on topic 2012 Acura MDX problems
you know I did that, I had an engine compression test and with no result, compression test done, all cylinder good,
4 years 4 months ago #56659 by Noah
Did the misfire go away changing the spark plugs, and then eventually return? Or did it not improve at all?
I see quite a few of those with bad oil sealing rings. They consume oil and fowl plugs, usually on the rear bank.
4 years 4 months ago #56667 by JoseG
the misfire still there on 2 and 3 cylinders, I took it back to the dealer, the mechanic thinks it a stuck rocker arm or faulty injector, but I change the injectors with new ones. He change around the spark plug and coils but still misfire in the same cylinders 2 and 3. I thought about the harness wire but he didn't seem to interested, but wanted to explore more, so I just brought the SUV home.
4 years 4 months ago #56686 by juergen.scholl
Replied by juergen.scholl on topic 2012 Acura MDX problems
Verifying the mechanical condition is a starting point that would makes a lot of sense imo..... Do you have any freee frame data to share?
Depending on tooling and knowledge you may start with something as simple as a vacuum gauge and might end with pressure transducer analysis. Do you know wether/when the valves were adjusted?
