B2477-60: Module configuration fault. 2014 Mustang GT.
- 70monte
- Thank you received: 29
I bought this car new and the only thing that I could think of that could possibly cause this code is that I did have both airbags replaced under the airbag recall. I have not had any other modules replaced. Car only has about 34,000 miles on it.
Do you guys think that it's possible that the airbags were not configured correctly? Is there anything else that could cause this fault to show up. This did not set off the CEL so I have no idea how long I've had this code stored. Thanks.
- JEFFSSEI
- Thank you received: 13
- 70monte
My scan tool was not able to change the tire size and I'm not sure if it can rewrite info to any of the modules. I may have to go the Forscan route. I have read that Forscan is now very picky on what cable you use with it. Do you have a link for the one you use? Thanks.
- Matt T
- Thank you received: 276
If you already have a J-Box you can use Forscan with it. If you need to buy something get an OBDLink EX or MX+. EX is cheaper if you're gonna run Forscan on Windows and don't mind being tethered.
www.obdlink.com/
- 70monte
- JEFFSSEI
www.amazon.com/OBDLink-EX-FORScan-OBD-Ad...n%2Caps%2C425&sr=8-5
The MX Matt Mentioned:
www.amazon.com/OBDLink-Bluetooth-Profess...%2Caps%2C425&sr=8-16
The MX wasn't out when I bought my cable - at the time it was the "Best" cable on the market and wired wise it probably still is if not then 2nd (don't cheap out and get one with a switch - I've used one a friend had it was annoying switching back and forth). oh and if you get one, check obdlink's website they have updated the firmware for my EX cable several times...definitely want to be on the latest firmware...the obdlink ones also come with a free copy of OBDWIZ scantool software (the serial key for it is printed on the card in the package your cable comes in) that you can unlock other upper level/advanced scanning features for. I have the professional unlock for GM vehicles as I work on those a lot (it only gives access to full PID list, no bi-directional controls as far as I have seen while using the obdwiz software).
THE biggest thing I can say with forescan is (1.) ALWAYS save a backup of your current configuration before making any changes. (2.) Don't forget to hit the stop/end button before you go to a different tab otherwise you will probably have to go back to that tab to "end" doing what you were doing in there before it will let you do something in another tab (gets annoying trying to figure out why it won't let you do anything...learned the hard way). (3.) Read, read read on their forums before you make changes especially if it requires you to change as built code manually. (most of the popular mods are already coded) (4.) until you get "comfortable with Forescan, make one change, then test things out make sure the change was correct and didn't cause any issues anywhere else. (5.) search their forum first and look for a spreadsheet for your year/model of vehicle...if you can't find one then ask, but search first.
- 70monte
- 70monte
I did have this module replaced under warranty back when the car was new due to a delaminated display screen.
My scan tool does give me the option to program this module so I may try doing so and see what happens. Hopefully it won't screw anything up.
- 70monte
- JEFFSSEI
side note .... if you really want it back forscan could probably get that mustang part back...I know on my friends 2013 F150 FX4 I changed his startup screen on the gauges to the Ford Raptor startup logo. that program never ceases to amaze me what it can do on Ford and Mazda vehicles....if only there was one like that for GM vehicles (me being a gm guy and all) I'd pay whatever they asked for that level of access.
- 70monte
I may try adding those two things back in once I get forscan up and running but I'm curious if it will cause an error code again since those two things are not original to my car.
- JEFFSSEI
- 70monte
I'm not sure if they have lifetime licenses any more. I saw one for a year. I should get my cable tomorrow so I will probably hook it up and see what info it provides and what it can do. Thanks for all of your help.
- JEFFSSEI
Lifetime License - yeah I saw that the other day...it was available for years, I was surprised to see it wasn't available anymore...guess I'm glad I got it when I did. either way for me using at the shop 4-5 times a year, it's paid for itself easily for me, and if I didn't have the lifetime one, I'd pay for the annual subscription just to support them for how awesome a product they have, maintain and update.
- 70monte
- 70monte
