P1137 add fuel bank 1 rich
  • Diesel
  • Diesel's Avatar Topic Author
4 years 5 months ago #56255 by Diesel
P1137 add fuel bank 1 rich was created by Diesel
Hi guys. I have a 2001 gti vr6 2.8l
I rebuilt a motor only addition is 268 cams & titanium valve kit.
I have been getting p1137 code for a month I have put new maf, injectors,o2 x 2, purge control valve , fpr fuel pump fuel filter & after each install keep getting same code.
ok i got some data from the torque app scanner.
At idle
MAF: 6.0g/s
STFT: 2.3%
02 1×2: 0.4V
LTFT: -14.8%
VOLTS (AD): 13.9V
FUEL FLOW: 38.6CC/MIN
FUEL FLOW: 2.4L/HR
UNDER LOAD 11.8%
MAF: 15.2G/S
STFT: -10.9%
02 1×2: 0.6V
LTFT: -14.8%
VOLTS(AD): 14.0
FUEL FLOW: 92.9CC/MIN
FUEL FLOW: 5.6L/HR
UNDER LOAD 2500RPM IM GETING NEGATIVE 17 STFT.
ANY HEELP WOULD BE GREAT Thank you.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 5 months ago #56269 by VegasJAK
Replied by VegasJAK on topic P1137 add fuel bank 1 rich
Fist thing that stands out is the g/s... 6g/s at idle. With a 2.8l engine should be reading in the range of .8 to 1 g/s
