Normal loping and misfire
- jerry r
4 years 5 months ago - 4 years 5 months ago #56206
by jerry r
Normal loping and misfire was created by jerry r
I have a amateur question, how do you tell the difference between looping ,because of valve overlap ,or a misfire at idle?
Last edit: 4 years 5 months ago by jerry r.
4 years 5 months ago #56207
Replied by Noah on topic Normal loping and misfire
Most unmodified engines will have very little valve overlap at idle.
A small block v8 with a performance camshaft will lope at idle, a stock four cylinder Honda engine should not.
The following user(s) said Thank You: jerry r
- juergen.scholl
- Active partschanger
- Thank you received: 462
4 years 5 months ago #56210
by juergen.scholl
A scanner may show significant shifts in fuel trims due to misfire.
If available a cylinder contribution test is a great tool either with a scanner or an oscilloscope.
Replied by juergen.scholl on topic Normal loping and misfire
I have a amateur question, how do you tell the difference between looping because of valve overlap and a misfire at idle?
4 years 5 months ago #56213
Replied by Tyler on topic Normal loping and misfire
As far as road-going passenger vehicles, noticeable idle loping is almost always a problem. :silly: Even on vehicles with aggressive VVT systems that make use of scavenging and catalyst heating strategies, your average car owner won't know the difference.
- jerry r
4 years 5 months ago - 4 years 5 months ago #56253
by jerry r
Replied by jerry r on topic Normal loping and misfire
How about a 2003 Chevy suburban 5.3 ? Stock, for example
