No crank 04 c230
4 years 5 months ago #56106 by Sirpe
No crank 04 c230 was created by Sirpe
2004 c230 no crank, obd link error. Blew a hose, slight overheat, now nothing. Shows red warning "coolant" on instrument panel randomly. Filled both reservoirs. Bench tested starter. Fuses, relays. Tried jumping starter, bendix engaging does not spin starter. Jump starter motor only, it spins. Won't engage bendix and spin motor together.
4 years 5 months ago #56117 by Tutti57
Replied by Tutti57 on topic No crank 04 c230
Can you get a amp reading while trying to start it? How about voltage drop test at the starter while cranking?
Is the battery good and fully charged?
You are not able to communicate with the ecm?
4 years 5 months ago #56119 by Cheryl
Replied by Cheryl on topic No crank 04 c230
Is the engine locked up?
