2015 vw Passat 1.8 turbo missfire
  • ed2
  • ed2's Avatar Topic Author
4 years 6 months ago #55561 by ed2
Hi I have an odd one here , came in with misfire. cust had changed plugs and coils, all factory , Vehicle has misfire on cyl 2 at idle. Tested coils & plugs, did compression test .Cylinder 2 is approx 30 lb lower than other cylinders , did a running compression test and other cylinders are 0-80 lb, but cylinder 2 is 0-50 . Performed a leakdown and leakdown is excellent .Pulled intake and cleaned carbon, also replaced #2 injector while i was there, . do you think the compession is low enough to cause a almost dead miss at idle? I have checked spark and is is good all the time. I tried to scope injectors, but i cant get a good wave on any cylinder -even the good cylinders. I attach photo shortly .Anyone have any idea I am kind of torn between mechanical issue , or computer. any ideas? Maybe a valve is not opening all the way or something, That would still have good leakdown. Thanks ed
  • ed2
4 years 6 months ago #55569 by ed2
Replied by ed2 on topic 2015 vw Passat 1.8 turbo missfire
  • ed2
4 years 6 months ago #55571 by ed2
I have checked my scope ground several times.... also used different scope same result.
4 years 6 months ago #55599 by Noah
Replied by Noah on topic 2015 vw Passat 1.8 turbo missfire
Hey Ed,
What were the cranking compression values for each cylinder?
4 years 6 months ago #55645 by Matt T
Replied by Matt T on topic 2015 vw Passat 1.8 turbo missfire
Looks like GDI injectors. And FWIW if the #2 injector looks different that may be a reaction to the misfires rather than the cause of them.
www.picoauto.com/library/automotive-guid...voltage-and-current/
IMO there's plenty of evidence to justify further testing on the low compression issue. Piezo on the intake would be a good quick test. Running in cylinder transducer is another option. Or you could go old school and pull the valve cover :lol:
