2013 GMC Terrain p0017
- XsleepercellX
- Thank you received: 7
Does any one have any idea as to why the pcm isn’t controlling the exhaust cam and more so why I have 2.42 volts on both control wires but no control on the exhaust side.
I believe that answer will depend entirely on what the exhaust camshaft desired angle is while you're taking your measurements. If the PCM desires intake camshaft change but not exhaust, then that'd account for your readings.
Likewise, if the PCM has detected a base timing problem (and set a P0017 as a result), then the PCM will not command any camshaft angle change. That's why the presence of the code is key - if the PCM set P0017 as current, then it won't command the exhaust camshaft to change.
What’s normal operation KOER at idle of the exhaust cam vvt solenoid and what’s with the 2.4 volts but no control during idle or test drive??
Again, that depends on what the PCM desired angle is. :silly: 'Normal' operation will depend on a variety of factors, including engine temperature, throttle angle, engine load, like that.
- XsleepercellX
- juergen.scholl
- Active partschanger
- Thank you received: 462
If you could go in-cylinder with a pressure transducer to look at valve timing.....
Another option is to check out ckp/cmp relationship comparing to known good captures taken under the same conditions, eg VVT solenoid unplugged.
You also can activate the solenoid manually and look for a change in ckp/cmp relation just to confirm/discard the solenoid itself is working.
I would not be surprised to hear the base timing is off.
8-;
- XsleepercellX
Yes I did clear codes and the code would set almost immediately but the light wouldn’t come on. Takes a bit to get the light to come on but code sets immediately
If the P0017 resets almost immediately, then there's some kind of base timing issue.
The exhaust camshaft desired angle is a zero because of the P0017. Your known good vehicle has a desired angle because the PCM decided very early in that key cycle that there was no base timing issue.
A cam/crank waveform would be nice to have, since this came from another shop and all.
f01.justanswer.com/indy-tech/9bde6d42-ae...06ef70d119_P0016.pdf
Read the PI very carefully before calling a camshaft. The pictures are from an LE5 engine, NOT the LEA in your Terrain.
- XsleepercellX
