Map sensor testing
  • robert.whitman
  • robert.whitman's Avatar Topic Author
4 years 6 months ago #55456 by robert.whitman
Map sensor testing was created by robert.whitman
I am trying to test my map sensor on a 1992 Toyota Corolla 4a-fe engine. I need the procedure and correct multimeter values.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 6 months ago - 4 years 6 months ago #55476 by VegasJAK
Replied by VegasJAK on topic Map sensor testing
3 wire pressure sensor. 5v ref, sig and ground.
You can do 2 ways. Disconnect vacuum line and use vacuum pump or KOER.
KOER back probe sig wire. Red lead of DVOM on DCv to sig, black to battery ground. Voltage at idle .5 to 1.5. Increase RPM, voltage will go up. WOT 4.5v
With vacuum pump, no vacuum 4-5v. Add vacuum voltage will drop. At 5 in.Hg → 3.9 Volts. At 10 in.Hg → 3 Volts. At 15 in.Hg → 2.1 Volts. At 20 in.Hg → 1.2 Volts. Approximately.
Last edit: 4 years 6 months ago by VegasJAK.
  • robert.whitman
4 years 6 months ago #55477 by robert.whitman
Replied by robert.whitman on topic Map sensor testing
Perfect... Thanks alot.
Do you know the procedure and values to test the pick-up coil in the distributor?
  • VegasJAK
  • VegasJAK's Avatar
4 years 6 months ago #55557 by VegasJAK
It's long. The testing is on part 2. Hope it helps.
