weak signal for coilpack 1 and 4
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 6 months ago #55590 by VegasJAK
Replied by VegasJAK on topic weak signal for coilpack 1 and 4
What generation Evo do you have?
  • brokemanevo
  • brokemanevo's Avatar Topic Author
4 years 6 months ago #55728 by brokemanevo
Replied by brokemanevo on topic weak signal for coilpack 1 and 4
2003 mit lancer evolution
evo 8
  • brokemanevo
4 years 6 months ago #55729 by brokemanevo
hey. so i have 3 wires for the crank sensor.
Ground
Battery +
Signal
Here are the steps taken to test crank sensor.
1-ignition key on
2-battery volt 13.0
3-disconnected coilpacks
4-meter to DCV
5- red probe to crank signal wire
6- black probe to ground (from the crank harness)
7- manually turned the motor and i get........
0.03 when crank wheel is not in-between crank sensor.
0 when wheel is in between sensor.
the crank is a hall effect sensor. that should only be 0-5V right?
  • VegasJAK
  • VegasJAK's Avatar
4 years 6 months ago - 4 years 6 months ago #55731 by VegasJAK
So, yes, you should have 5v on that crank signal wire... brown with a green tracer. With the KOEO and the sensor unplugged check the signal voltage. If 5v, the problem is the sensor. No 5v, problem is in the wiring as you appear to have some resistance on that signal wire. I have a crude wiring diagram which I'm looking at. It shows pin 43 at the ECM as the 5v for the crank. The crank, cam and air temp sensors share the same ground. Check for 5v at pin 43.
Forgot to mention... use a good block ground for your meter for all your testing, not the sensor ground wire.
Last edit: 4 years 6 months ago by VegasJAK.
  • brokemanevo
4 years 6 months ago #55732 by brokemanevo
i made a mistake.
i had the signal wire cut and tested it that way which gave me a bum reading of .03.
fixed the wire. got a 5V reading from signal wire.
so. cam sensor reads good, crank sensor reads good.
started the car and it is still on 2 and 3 cylinders.
still no spark at 1 and 4.
what is next to test?
signal wire for 2 and 3 reads .7-.8v
signal wire 1 and 4 reads .4.-.3
crossing out
cam sensor
crank sensor
and ecu.
  • VegasJAK
  • VegasJAK's Avatar
4 years 6 months ago #55733 by VegasJAK
Good work... this puts us back at square one. You have tested the 1-4 coil circuit. Test the 2-3 coil so we have comparative values to look at. Use a good block ground point for your meter ground and test each wire KOEO plugged in and unplugged.
  • brokemanevo
4 years 6 months ago #55735 by brokemanevo
Will do right now.
So test kOEO
signal, ground, Power for 2and3
same for 1 and 4?
  • brokemanevo
4 years 6 months ago #55736 by brokemanevo
12.2 power across 1-2-3-4
red to power pin connector
black to ground wire on chassis.
tested ground on all 4 coil pack connectors.
black probe to ground pin on coil pack
Red probe to power pin on coil pack.
12.2.
now for signal.
1 and 4 KOEO 0.4
2 and 3 KOEO 0.3
  • VegasJAK
  • VegasJAK's Avatar
4 years 6 months ago #55737 by VegasJAK
Ok... based on everything done to date, the engine should run on all 4. If coil 1-4 fires with the driver from 2-3 then the coils are good and so are the grounds. If the ECM checks Ok and works in another Evo8 then the drivers for both coils are good. Only other thing is you ran a proxy wire from the ECM pin 10... the schematic i'm looking at says pins 11 and 12 are the coil drivers, and no joy. This zero's me in on the pins within the connector at the ECM and the coil for the 1-4 signal wire. Check them extremely close for bent or corroded pins. Check the female pins for drag, that is the male pin is firmly seated within the female pin and the male pin pins don't back out when the connector is connected to the ECM and coil. I mentioned it before, you can splice the 2-3 driver wire into the 1-4 and have the single driver work for both coils. You'll be up and running but it would be better to fix the problem.
If you get the chance, I believe the signal wire has a bias voltage on it, unplug either coil and with the KOEO let me know what the voltage is on the signal wire. Thanks.
  • brokemanevo
4 years 6 months ago #55738 by brokemanevo
Hello.
Thank you for the suggestions honestly this is my last hope. everyone else has failed to help me.
Also a learning process for me.
If i splice 1 and 4 to 2 and 3. would is safely be able to drive? this would cause misfire on 1 and 4 correct? i want to be able to take it to my shop so i can get to test more often.
  • VegasJAK
  • VegasJAK's Avatar
4 years 6 months ago #55739 by VegasJAK
If it was my car, I would continue to work on the fix. I offer the suggestion only as an alternative to try. I would surely test the work around before going out with it. IMO I see no reason it won't work as a temp fix. With a little more work you will find that wiring issue. The signal is there it just has to get to the coil via the signal wire.
I'll continue to think about this and offer help.
  • brokemanevo
4 years 6 months ago #55740 by brokemanevo
i will try to jump the wire and see how the engine takes it. shop is 20 min away. the signal is low compared to coil pack 2 and 3.
i just dont know what would cause that other thn the ecu.
Thank you!!!
  • VegasJAK
  • VegasJAK's Avatar
4 years 6 months ago #55743 by VegasJAK
I'd say you're right except the two ECM's you have work in another car. So the ECM's driver is working.
  • brokemanevo
4 years 6 months ago #55744 by brokemanevo
Correct.
I also tested both ecu my own way.
maybe you can tell me if its accurate or a good way to test.
KOEO i disconnected the ecu connector.
pin for 1 and 4 read 6v
pin for 2 and 3 read 6v
  • brokemanevo
4 years 5 months ago #55994 by brokemanevo
Alright so i got the car towed to my shop where i can now run any test to fix the issue.
I jumped the signal wire from 2&3(spark) to 1&4(no spark)
Looked at the coil pack 1&4 made sure it got spark by connecting a extra spark plug at the end of the coil pack. It sparks.
Put it back in the motor and made no difference to the motor. Sounds the same.
Whats the next test. Cam and crank sensor are tested and working.
  • VegasJAK
  • VegasJAK's Avatar
4 years 5 months ago #55997 by VegasJAK
When you swap coils, do you leave the plug wires attached to the coils or plugs. Trying to make clear, are the plug wires always attached to the same coil when you move them?
  • brokemanevo
4 years 5 months ago #55999 by brokemanevo
no i disconnect and put them on to the ones swapped over.
  • brokemanevo
4 years 5 months ago #56000 by brokemanevo
I had nothing but time so i went ahead and tested all coil packs i had. i have 2 sets of 4 coil packs and they all sparked. I feel better when i see the spark myself.
definitely not coil packs.
  • VegasJAK
  • VegasJAK's Avatar
4 years 5 months ago #56035 by VegasJAK
Check the trigger plate inside the cam angle sensor housing. It may be loose or mis aligned on the cam.
  • brokemanevo
4 years 5 months ago #56060 by brokemanevo
I replaced that already.
it is aligned correctly using the service manual.
Time to create page: 0.423 seconds
