H3 stall question
  • Bennett87
  • Bennett87's Avatar Topic Author
4 years 6 months ago - 4 years 6 months ago #55302 by Bennett87
H3 stall question was created by Bennett87
2006 hummer H3 3.5l inline 5
Started to stall throw engine lights, and idle erratically. Tested cylinder leak down and found that the intake valves on the cylinder head were leaking.
Purchased a rebuilt cylinder head did the install replaced front cover oil pump plugs pulleys and Timing set on the front of the engine only.
Took it for a drive would stall every once in a while. Hooked it up to a scan to relearned my crank position sensor. Went for a long drive everything was smooth and then it stalled again throwing crank position code again.
Replaced the crankshaft sensor and relearned. Now when I start it, it runs fantastic until operating temp hits then it shuts off like a key turn. Fuel trims appear to be good. I did notice 5v at both wires on the crank sensor. I am not sure what else to think other then a possible ECM fault. I will be taking it to the dealer to reset the ECM and update hopefully with some form of success. I am at a loss any body had something similar happen to them with the stall at idle operating temp?
Last edit: 4 years 6 months ago by Bennett87. Reason: more information added
2 years 4 months ago #65737 by Stymie247
Replied by Stymie247 on topic H3 stall question
Any resolutions on this?
2 years 4 months ago #65738 by Stymie247
2 years 4 months ago - 2 years 4 months ago #65739 by Stymie247
I have the same problem on an 09 H3 just after the timing chain was replaced. P0017 Runs fine for 15 minutes then dies and stop signs and turns.
Last edit: 2 years 4 months ago by Stymie247. Reason: Was a duplicate...
2 years 4 months ago #65749 by Noah
Replied by Noah on topic H3 stall question
If OP doesn't respond with the fix to their own issue, I recommend starting a new post of your own. That way you can keep the details of your job separate from this one. Having a question asked on top of an unresolved question just makes the whole thing harder to read through, and ultimately harder to help you.
2 years 2 months ago #66482 by H3Times2
Replied by H3Times2 on topic H3 stall question
I have the same problem with my H3. Have you found the solution to the problem yet?
