Starting but not running
  • Rene Beckles
  • Rene Beckles's Avatar Topic Author
4 years 7 months ago #55084 by Rene Beckles
Starting but not running was created by Rene Beckles
I have a 2005 CS lancer 4g18 engine
It's starting and cutting out after a minute or so and if accelerator is press
Crank and cam sensors and fuel pump changed
Tried an injector rail with pressure regulator throttle body and same thing
No codes on Diagnostic
Any suggestions
4 years 7 months ago #55086 by Ben
Replied by Ben on topic Re:Starting but not running
Did you check fuel pressure at rail?
  • Rene Beckles
4 years 7 months ago #55087 by Rene Beckles
Replied by Rene Beckles on topic Re:Starting but not running
Not directly as the pump was changed and I tried another rail with injectors so figured it couldn't to be that
4 years 7 months ago #55089 by Ben
Replied by Ben on topic Re:Re:Starting but not running
I would take a fuel pressure reading at rail with engine running. your description sounds like low pressure. Could be a defective pump, could be poor power or ground supply to the pump, could be a fuel line restriction.
  • Rene Beckles
4 years 7 months ago - 4 years 7 months ago #55090 by Rene Beckles
Replied by Rene Beckles on topic Re:Re:Starting but not running
Ok thank you will do that
The restriction might not be as the lines were blown out going back to the tank the old gas was pump out and new gas added with a treatment
However I'll check again tomorrow and will post the results
Last edit: 4 years 7 months ago by Rene Beckles.
  • Rene Beckles
4 years 7 months ago #55106 by Rene Beckles
Replied by Rene Beckles on topic Starting but not running
Good evening thanks so much for the replies I fot the problem fixed
It was the filter as the pump is assembled into the filter we changed the pump but not the filter
Thanks once more for the help
Time to create page: 0.343 seconds
