MB 200 tourer (mdl 245.233)
- robert.lesaca
- Thank you received: 19
9 years 6 months ago #8272
by robert.lesaca
MB 200 tourer (mdl 245.233) was created by robert.lesaca
Anyone ever had an experience with PO793 (intermediate shaft speed sensor A circuit no signal)?
Thanks.
Robert
Thanks.
Robert
- Thank you received: 1138
9 years 6 months ago #8377
Replied by Noah on topic MB 200 tourer (mdl 245.233)
Hey Robert!
I don't have any specific info about this car (if you post the year someone may be able to pull up some service info), but I'm willing to bet it's a VRS type sensor that generates it's own voltage.
I'd start by checking live data if you have a scan tool that will display transmission data.
Next I'd want to check the actual signal at the sensor and at the PCM.
This video should give you a good idea of how to check the circuit:
- robert.lesaca
9 years 6 months ago #8381
by robert.lesaca
Replied by robert.lesaca on topic MB 200 tourer (mdl 245.233)
Hi Noah...thank you for taking your time. This is a neighbors car. I found the tranny almost dry of transmission fluid and I believe it had been driven like that for time so one can just imagine what might have happened inside the tranny ! Funny thing is MB dont have dipsticks in their tranny, at least for the newer models, after 2003 or thereabout. Had the following DTC's ; (1) PO974, PO720, PO793, 00D2/00D4 (readout fault memory of control unit CVT), PO722 and PO896...have not done any wiring integrity as Idont have a diagram and not familiar withMB esp their DTC description. But I will watch your video. I will keep you posted. Thanks once again.
- robert.lesaca
9 years 6 months ago #8382
by robert.lesaca
its a 2008 , MDL 245.233 B170 NG, Blue Efficiency B200 Tourer (whew...!)
- robert.lesaca
9 years 6 months ago #8598
by robert.lesaca
Hi Noah...AFter filling up tranny gear oil, it shifting work well for a few minutes. I checked integrity of of wiring from PCM to 3-wire sensor and all feed, ground and signal ok. My feeling is shift solenoid is the problem.I recommended it need to be serviced by the dealer(dash showed message "transmission need service soon"). Owner decided against it and wants to get rid of the car.
So I guess I consider this case CLOSE...
- robert.lesaca
9 years 4 months ago #9828
by robert.lesaca
CLOSE case...
