2008 Passat battery draining, stalls, and hesitate
  • davidessiendcarguy
  • davidessiendcarguy's Avatar Topic Author
4 years 7 months ago - 4 years 7 months ago #54912 by davidessiendcarguy
2008 Passat battery draining, stalls, and hesitate was created by davidessiendcarguy
Good morning sir. Yesterday a car owner called and drove me to a garage where is car was parked. On getting there, battery from is lexus was pulled out and used for my testing in his Passat.
  The car that is faulty is a 2008 Volswagen Passat. The  things I noticed when I connected my scantool were: P2014, P0113, P2185 were the check engine codes I saw. But when I checked for modules P0190, P0798, P0864 and P0841 were added previous 3 codes I highlighted earlier.
  Before long, about 7 minutes or less during my scan I wanted to crank the engine over to check the live data and the operation of the car unfortunately the battery went low.
   Hence, I couldn't carry out more test. In an interview of the car owner about what he used to notice/ symptoms in the car and what was replaced in the car in an attempt to solve the problem. He highlighted that it happened on is way,  when the car was on motion and suddenly went off. He allowed the car to cool down for some time. When he tried starting it again it started and moved for some distance and stalled out again.
    He invited an electrician to check the cause and fix the problem. The fuel pump was replaced and an actuator as he said but that he can't recall the name at the moment. The car was then driven to a garage where I meet it. Since then they've been trying to fix the problems permanently but to no prevail.
  Initially, most of the times the battery will drain out quickly and when car gets hot, the car will go off  on motion. At a point, the oil sump was broken too.
I asked him if he has ever noticed stalling of the car at idle, he replied: "not really".
    Consequently, the engine oil was replaced, top cylinder valves grinded,  oil switch, plugs, coils, top gasket and PCM were replaced but the problem was still not fixed.
  Moreover it was also noticed that mostly the car will hesitate whenever it wants to climb hill like a popping sound accompanied with that and move very slowly on smooth road.
   At present, the man said the car problem have gotten worst, it only cranks but doesn't start anymore.
Please help me out on how to solve  the car problems and get the car starting again.
Last edit: 4 years 7 months ago by davidessiendcarguy.
