2014 ram promaster 3.6 checking a faulty 5v ref
- Sleiman
4 years 7 months ago #54828
by Sleiman
2014 ram promaster 3.6 checking a faulty 5v ref was created by Sleiman
customer came in with fan always on and a check engine light
codes:P0118 ect voltage high
power side of the ect should be 5v instead its 12.7 with engine running
i followd the wire to the pcm and it giving 12.7 v (no short to voltage)
note ;sensor was replaced
do you guys think i should replace the computer?
thank you
thank you
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 7 months ago - 4 years 7 months ago #54829
by VegasJAK
Replied by VegasJAK on topic 2014 ram promaster 3.6 checking a faulty 5v ref
Unplug the ecm connector that contains that ECT 12.7v wire from the ecm and check the voltage at the corresponding ecm pin koeo. Sorry, don't have a wiring diagram to give pin number.
I'm thinking why don't you have other 5v ref on other sensor showing 12.7v. A problem with the ECT 5v ref will not bring down the entire 5v ref circuit because of the internal resistor, but I still wonder. Check the TPS. You could use the 5v ref from TPS for ect. ECM is expensive.
Last edit: 4 years 7 months ago by VegasJAK.
- Sleiman
4 years 7 months ago #54830
by Sleiman
Replied by Sleiman on topic 2014 ram promaster 3.6 checking a faulty 5v ref
i pulled out the wiring diagram and followed the wire to the ecm(pin12) i then cut the wire and had the engine running and still giving 12.7v
all other 5v ref circuits are working normal
do you think their is any other variable?
- VegasJAK
4 years 7 months ago - 4 years 7 months ago #54838
by VegasJAK
What circuits are on either side of of pin 12? Maybe one of the two other pins are shorting to pin 12 in the connector.
Were you able to use an alternate 5v supply and resolve the P0118?
