96 ford e350 with a 460 no start
  • David117
  • David117's Avatar Topic Author
4 years 7 months ago #54776 by David117
96 ford e350 with a 460 no start was created by David117
My 96 road e350 won’t start. I purchased it a couple of weeks ago and I’ve done some tests. Also I should mention it hasn’t run in a year. First symptom is the coil has 12 volts. When I test the spark with a spark tester it sparks constantly when I turn on the key but it’s a weak spark. No change when I crank it over. I changed the coil with a new one with no change. I can get the fuel pump to run by jumping it at the test plug under hood. Also no check engine light ever. It’s also got a new distributor. I tested the ICM and it’s getting 10 volt’s on the top wire and 4 to 5 volts when cranking so I assume the pip is ok. I’ve also cleaned all of the ground wires I could find. Is it my computer?
  • David117
4 years 7 months ago #54783 by David117
Replied by David117 on topic 96 ford e350 with a 460 no start
I forgot to mention my scanner won’t communicate with the computer. It has a obd2 connector under the dash with power on pin 16 and ground on 4. It also has an obd1 under the hood which is where I grounded the fuel pump wire which is the only way the fuel pump will come on. I also forgot to mention it’s a coachman 30 ft motor home.
  • David117
4 years 7 months ago #54796 by David117
Still no response? I’m new on this site. I guess I did something wrong. If I did please advise. I would appreciate some help. Thanks.
4 years 7 months ago #54801 by washer
Replied by washer on topic 96 ford e350 with a 460 no start
I don't think you did anything wrong, but, your posts are a big difficult to follow. You say you "get spark constantly when you turn on the key". Then you add "No change when I crank it over".
Are you implying you've got spark while the engine is NOT turning over?
  • David117
4 years 7 months ago #54804 by David117
That is correct. It starts sparking as soon as I turn the key on. Then there is no change in the spark when I spin the engine over. The spark looks weak though. I’m using a spark tester to test.
4 years 7 months ago #54806 by washer
Wow, that's crazy. Something must be intermittently commanding the coil to fire, or some module is bad. That's not at all normal.
Is there any chance you have access to an o'scope?
4 years 7 months ago #54807 by washer
Can you take a picture of your ICM and post here? Also, explain what you mean by "the top wire"
  • David117
4 years 7 months ago #54834 by David117
I don’t have access to a scope but I will take pictures of the module with the connector. I think the top wire that I was testing was brown or tan. I read that the color of the module matters? I have a black one. Thanks for your help!!
4 years 7 months ago #54839 by washer
Ok. I'll await the photo(s)
  • David117
4 years 7 months ago #54847 by David117
  • David117
4 years 7 months ago #54849 by David117
I tested the wires going to the module again. I have power, I have a ground, and I have a pip signal from the distributor. So I unplugged the module and the coil stopped sparking with the key in the run position. So I have inspected the harness and I can’t find anything obvious so if I plug the module back in and unplug the computer would that tell me anything? Something is shorted and I don’t know how to find it. Thanks
4 years 7 months ago #54850 by washer
Power on which Pin. Did you load test it?
Ground on which Pin. Did you load test the ground?
Do you have PIP signal while the engine is NOT cranking? If yes, describe what you are seeing.
While cranking, what do you see with a test light on the PIP pin?
  • David117
4 years 7 months ago #54867 by David117
Power on pin 3, ground on pin 1. I tested the coil control on pin 2 with the test light and it flickered just like at the coil with koeo and koec so the circuit there is good. I tested the pip on pin 6 with my volt meter and the voltage was all over which I would think the icm is getting a pip signal from the distributor. I’m not sure how to test the power and ground with a load?
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 7 months ago #54870 by VegasJAK
Replied by VegasJAK on topic 96 ford e350 with a 460 no start
David117... I have a different pinout for your icm. Pin1 gry/o is pip from pcm, pin2 pink is spout from pcm, pin3 is wht/p 12v from pcm, pin4 is red/lg 12v from fuse panel for hot in start/run, pin5 is tan/v to coil and pin6 blk/w is ground to distributor.
In any event, I believe you're getting false signals from the pcm to the icm as you're getting pulsing spark in KOEO position as well as no fuel pump signal. I just hate calling a bad pcm and I'm not now, just pointing you in that direction. PCM sends icm signal to pulse based on inputs from sensors. If engine not cranking should not have pulsing spark at coil.
4 years 7 months ago #54871 by washer
Ok, for giggles, pull the SPOUT connector. If you STILL have a pip signal KOEO than your problem has to be upstream from there. Can you grab a junk yard distributor and play swap-tonics?
  • David117
4 years 7 months ago #54875 by David117
I checked your pins with mine and they are the same just numbered different. My wiring diagram starts at the bottom of the plug with black being #1 and the top being #6. If I started at the top with #1 it would match what you have if I’m looking at it right.
4 years 7 months ago #54877 by washer
This is why I suggested he remove the SPOUT. If I remember correctly, with that removed, there's not signal from the ECM to the ICM
4 years 7 months ago #54884 by washer
That's my understanding/memory of this all too.
I have to say I've never heard of this issue (spark without cranking).
The following user(s) said Thank You: David117
  • David117
4 years 7 months ago #54893 by David117
I disconnected the spout connector and the coil started firing as it should. I gave it a shot of starting fluid and she started. Fuel pump still won’t run without jumping it. Does this mean I need a new computer?
4 years 7 months ago #54894 by ontheriver
Replied by ontheriver on topic 96 ford e350 with a 460 no start
You mentioned, no check engine light, so the ecm is not getting power, a quick search showed a ecm power relay powers ecm and fuel pump relay
Time to create page: 0.382 seconds
