Fan Switch/Blower
- whiskywaterwine
4 years 7 months ago #54674
by whiskywaterwine
Fan Switch/Blower was created by whiskywaterwine
Im a DIYer bigtime.....need help.....
My blower motor works just fine. Its the fan selector switch , it doesnt work to automate
to the different channels i want to select.
How do i repair this?
do i just switch out the unit the actual switch is connected to?
its for my 2000 Chevrolet Express Van 1500 5.7 liter
kind regards
thomas smith
kind regards
thomas smith
- Matt T
- Thank you received: 276
4 years 7 months ago #54692
by Matt T
Does this mean the fan speed switch doesn't change blower speed? Or the mode switch doesn't switch between defrost and vent and whatnot?
And if it's fan speed that isn't changing is it stuck on high and stays running with the key off?
Replied by Matt T on topic Fan Switch/Blower
- whiskywaterwine
4 years 7 months ago #54697
by whiskywaterwine
Replied by whiskywaterwine on topic Fan Switch/Blower
It is the mode switch. Blower speed is controllable.
Thanks
Thanks
4 years 7 months ago - 4 years 7 months ago #54703
Replied by Andy.MacFadyen on topic Fan Switch/Blower
Is it a switch or is it controlled by a module ?
If it is switch and simple resistor pack and the low speeds aren't working but high speed is okay the chances are it is the resistor pack itself .
Also because the blower fan use a lot of amps the connector and the switch contacts often suffer burning due to arcing, so look for signs of over heating at the connectors. Simple way to test the switch is use a test light and also do by-pass test.
The other type uses a computer module in place of a simple switch and a power transistor pack in place of the resistor pack.
If it controlled by a computerised control module using pulse width modulation and it is working at high speed only then if it is usually the module. To test I would use an oscilloscope but it can be done using a voltmeter or test light but requires a bit of knowledge in what to look for,
Last edit: 4 years 7 months ago by Andy.MacFadyen.
- Matt T
4 years 7 months ago #54732
by Matt T
Most likely a vacuum leak. I'd start with checking the lines in the engine bay. I've attached a diagram showing the location of the vacuum tank. Should be one line from it to the intake and another going to the firewall.
