E53 X5 stay on open loop
  • arikaryadi
  • arikaryadi's Avatar Topic Author
4 years 7 months ago #54644 by arikaryadi
E53 X5 stay on open loop was created by arikaryadi
Hi all,
I have E53 x5 BMW 2004, the car stay on open loop, both O2 sensor show 0v. But there is no engine light on. The owner said, it consume a lot of fuel. I was suspecting it's the O2 sensor fault. Does the downstream O2 should operate as it should or should it also shows 0v too? by the way, the ECT shows normal temperature around 98C.
Cheers guys.
  • VegasJAK
  • VegasJAK's Avatar
  • Silencing the Parts Cannon
4 years 7 months ago - 4 years 7 months ago #54650 by VegasJAK
Replied by VegasJAK on topic E53 X5 stay on open loop
Check power and ground of heater circuit of 02's. Could be a blown fuse. Are you seeing 0v in scan tool pid? KOEO unplug 02 does voltage stay at 0v or show voltage? If 0v signal wire shorted. If voltage sensor is bad.
Last edit: 4 years 7 months ago by VegasJAK.
