[FIXED] 98' Honda Accord pass side fuse box 10A fuse blown
- jjgarcia
- cheryl hartkorn
- Thank you received: 130
- Ben
- Thank you received: 215
- jjgarcia
- jjgarcia
- cheryl hartkorn
cheryl hartkorn wrote: well you could remove the fuse and put in place a headlight bulb it will light due to the short. and start unplugging things until it goes out. or remove the headlight switch and use a fused jumper wire between pins 6 and 7. red/green red/black and take the switch out of the equation
Exactly what I was going to suggest. This is much better than continually swapping fuses, and gives you a nice visual clue.
Here's a link to the courtesy lights diagram, from BBB Industries . Let me know if this works.
drive.google.com/file/d/0BwIz-f3J815JWXp...Zlk/view?usp=sharing
IMO, the rear lights are the most suspect, so I'd suggest going there first. Keep your eyes open for melted connectors and wiring. Everything up and to the bulbs themselves is suspect. Also, check out the top of the second page, C554. That's the power feed to all the rear courtesy lights. If we can ID and unplug that connector, and the short goes away, then we can be pretty confident the short is in the rear.
Unfortunately, I can't trace connector locations on BBB Industries, maybe someone else with access to service info can help me out?
- cheryl hartkorn
cheryl hartkorn wrote: tyler does Mitchell do connector pinouts like all data?? I don't have Mitchell just no data. does it give connector locations etc??
Sometimes? :lol: Fantastic coverage for connector locations/pinouts on domestics, hit and miss for imports. Really wish I could find a free source for stuff like this.
- Thank you received: 1138
It would be a long shot to say the least if this ended up actually being the problem, but I just wanted to share my experience with you.
- jjgarcia
- jjgarcia
- jjgarcia
- jjgarcia
I ended up picking the right diagram for fuse #10, and I believe you were looking at C554. That the breaker kept popping after you disconnected it makes sense since you found the short up front. Nice job on the breaker, by the way.
Is that the red/black wire burned through? Since you found it under the air filter box, I'd suspect that wire is actually in this area on the diagram:
- Nandor69
- Thank you received: 5
