What am I missing!
- Mrwrench
4 years 8 months ago #54542
by Mrwrench
What am I missing! was created by Mrwrench
Vehicle is 2010 equinox, 2.4l
Codes are p0092 and p00c9
Fuel Pressure Regulator 1 Control Circuit High and Fuel Pressure Regulator High Control Circuit Low Voltage
Have tried multiple high pressure pumps and a new pcm. It’s a 2 wire system power supplied by pcm and ground is pwm also pcm controlled. Where would you guys go next?
Thanks for any help guys!!
- Mrwrench
4 years 8 months ago - 4 years 8 months ago #54545
by Mrwrench
Replied by Mrwrench on topic What am I missing!
Have also repined ecm pin 16 and 32, new wires and connector on high pressure pump,
Didn’t have hope for this beings the codes weren’t open codes, but had to rule it out thanks can’t wait for more replys!!
Last edit: 4 years 8 months ago by Mrwrench.
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
4 years 8 months ago #54547
by VegasJAK
Replied by VegasJAK on topic What am I missing!
The fuel pressure sensor.
- Mrwrench
4 years 8 months ago #54553
by Mrwrench
Thanks for the quick response, above I attached the wiring diagram, the codes are circuit codes unless I’m looking at it wrong the low pressure side should not effect this, if anyone has any ideas I would entertain anything!
- Matt T
- Thank you received: 276
4 years 8 months ago #54554
by Matt T
New wiring from the ECM or just a new pigtail?
Are these hard codes? If not when are they setting?
Found an interesting TSB on interference from aftermarket lighting setting both codes on GM GDI applications.
Replied by Matt T on topic What am I missing!
- VegasJAK
4 years 8 months ago - 4 years 8 months ago #54555
by VegasJAK
Diagram did not attach... I was thinking you were posting a new diagram
I really dislike those generic diagrams.
The fuel pressure sensor sends it's signal to the pcm which controls the high pressure fuel pump circuit on and off.
Last edit: 4 years 8 months ago by VegasJAK.
- Mrwrench
4 years 8 months ago #54556
by Mrwrench
Two New wires from ecm and new pigtail at the high pressure fuel pump, thanks guys I really appreciate your guys opinions, I’ll try to get diagram to attach
Would also love the tsb you found
- Matt T
4 years 8 months ago #54557
by Matt T
It's attached to the earlier post I mentioned it in. Should download, or open, a pdf when you click on it.
- Mrwrench
4 years 8 months ago #54559
by Mrwrench
Thanks Matt, an interference could be the culprit, will look into that!! Any other suggestions are greatly appreciated
