Vauxhall Insignia no starter
4 years 8 months ago - 4 years 8 months ago #54438 by Leone
Vauxhall Insignia no starter was created by Leone
Hi, I have a non starter Vauxhall insignia 2.0 diesel 2011with a bunch of dtc’s which are in order
P0336-00
P062B-5C
C0561-71
U0121-00
U0140-71
U0164-00
Now the p0336-00 is cured as I replaced the crankshaft sensor and the camshaft sensor at the same time because after replacing crank sensor it came up with a dtc for cam sensor, also done a voltage test on cam sensor wires and with ignition on I only get 4 volt on reference and signal wires instead of 4.8-5 volt, ground has 2.3 ohms resistance. Any ideas would be much appreciated. Thanks
Last edit: 4 years 8 months ago by Leone.
4 years 8 months ago #54456 by derekoliveira
Replied by derekoliveira on topic Vauxhall Insignia no starter
Check ecm connector to see if there any corrosion or samething else that can make bad contact.
Time to create page: 0.256 seconds
