1996 Ford F 150 4.9 L6
  • toadyboy1957
  • toadyboy1957's Avatar Topic Author
9 years 6 months ago #8098 by toadyboy1957
1996 Ford F 150 4.9 L6 was created by toadyboy1957
I need a POWER STEERING PUMP for a 1996 Ford F150 4.9 liter 6 cylinder i cant afford a 400 dollar new OEM pump I HAVE A CHOICE OF 3 REMAN PUMPS// VISION OE , BBB INDUSTRIES , OR CARDONE PUMP // Which is the best of the 3
9 years 6 months ago #8099 by Ben
Replied by Ben on topic Re:1996 Ford F 150 4.9 L6
Everyone will have a different opinion on what has worked for them . I use to use Cardone until late I installed 3 faulty ps pumps in a row! I was so tired of doing that job over and over again.... I use bbb now and haven't had a problem but it doesn't mean someone else hasn't!
The following user(s) said Thank You: toadyboy1957
  • toadyboy1957
9 years 6 months ago #8106 by toadyboy1957
Replied by toadyboy1957 on topic 1996 Ford F 150 4.9 L6
i am believing more and more a short in these wires is very highly likely what TOOK OUT THE FUEL PUMP DRIVER out of my PCM WHERE THE UNCOATED WIRE WAS WRAPPED ROUND THE OTHER WIRE HAD BARED THE OTHER WIRES IN SPOTS AFTER I GOT IT ALL UNCOVERED
  • toadyboy1957
9 years 6 months ago - 9 years 6 months ago #8107 by toadyboy1957
Heres some pictures
Last edit: 9 years 6 months ago by toadyboy1957.
  • toadyboy1957
9 years 6 months ago #8143 by toadyboy1957
because these wires were so tightlky bound and the 1 wire had no coating it cut through the other 2 wires it was wrapped around and literally rubbed baren spots in the coated wires IM ALMOST POSOTIVE that is what took out the relay which in turn took out the fuel pump driver in the pcm i have redone all wires and rewrapped all wires in all the harnesses
9 years 6 months ago #8145 by Ben
Hey that certainly needed fixed!
  • toadyboy1957
9 years 6 months ago #8148 by toadyboy1957
it got taped all by itself and put in the harness and the covering retaped over all the wires after the connector was repaired as well
  • toadyboy1957
9 years 6 months ago #8153 by toadyboy1957
ben is it normal protocall for ford to factory wire something like this at the FACTORY?? have you ever seen anything like this ??
9 years 6 months ago #8155 by Ben
Yes old wires fall apart especially if they have been in contact with oil
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
9 years 6 months ago #8168 by ScannerDanner
Replied by ScannerDanner on topic 1996 Ford F 150 4.9 L6
toadyboy1957 wrote: because these wires were so tightlky bound and the 1 wire had no coating it cut through the other 2 wires it was wrapped around and literally rubbed baren spots in the coated wires IM ALMOST POSOTIVE that is what took out the relay which in turn took out the fuel pump driver in the pcm i have redone all wires and rewrapped all wires in all the harnesses
That looks like some type of shield wire which would be a ground.
Your fuel pump driver is ground side switched. If that wire was shorted to ground it would NOT hurt the driver. Only a short to power would have done that in this case
Don't be a parts changer!
9 years 6 months ago #8169 by Ben
Replied by Ben on topic Re:RE: 1996 Ford F 150 4.9 L6
I agree that is a shield wire. and from what I remember your relay was drawing 2 amps which would be what took out the driver
  • toadyboy1957
9 years 6 months ago #8263 by toadyboy1957
The relay was drawing 3 amps b4 i switched relays with the trailer brake relay then was a 300 milliamp draw so i replaced that relay with new 1 and with those wires being drenched in oil led me to deeper search which i uncovered and found quite a few wires minus coating so i got an old harness from and old junker 93 f 150 all same wiring dissassembled that harness and cleaned each wire made sure each wire was good and reassembled my connectors with the good wire and sheathed each section then wrapped each sheath with 10 mill vinyl tape and then wrapped again with black electrical tape // allk of this wiring is like factory now and completely sealed from dirt oil and any moisture // here is a couple of pictures of the finished ptroduct//
THIS IS A FIX
9 years 6 months ago #8268 by Tyler
Replied by Tyler on topic 1996 Ford F 150 4.9 L6
Looking good to me! B) So is it back to starting like normal?
  • toadyboy1957
9 years 6 months ago #8270 by toadyboy1957
still have the fuel pump driver issue and the ground issue havent replaced the pcm yet tyler
9 years 6 months ago #8275 by Tyler
toadyboy1957 wrote: still have the fuel pump driver issue and the ground issue havent replaced the pcm yet tyler
No worries, just excited to hear that this thing starts as designed! :lol:
  • toadyboy1957
9 years 5 months ago #9659 by toadyboy1957
Since the last time i posted I had REDONE all the wires, replaced the Dustributor and Spark Plugs and put it all back together i get in turn the key on and i hear the fuel pump constantly / try to start it and it wont start both front and rear fuel pumps are brand new fuel is coming out at the filter but still wont start // any suggestions please and THANKS GERALD
  • toadyboy1957
9 years 5 months ago #9690 by toadyboy1957
Since the last time i posted I had REDONE all the wires, replaced the Dustributor and Spark Plugs and put it all back together i get in turned the key on and i hear the fuel pump constantly / try to start it and it wont start i pulled the fuel line off at the filter was a small stream of fuel surely not 50 PSI both front and rear fuel pumps are brand new fuel is coming out at the filter but still wont start .. IT has great spark // any suggestions please and THANKS GERALD
  • toadyboy1957
9 years 5 months ago #9694 by toadyboy1957
toadyboy1957 wrote: Since the last time i posted I had REDONE all the wires, replaced the Dustributor and Spark Plugs and put it all back together i get in turned the key on and i hear the fuel pump constantly / try to start it and it wont start i pulled the fuel line off at the filter was a small stream of fuel surely not 50 PSI both front and rear fuel pumps are brand new fuel is coming out at the filter but still wont start .. IT has great spark // any suggestions please and THANKS GERALD
Time to create page: 0.597 seconds
