2008 F250 5.4 misfire codes
- fixn_junk
- Thank you received: 3
- Cheryl
- Thank you received: 215
- Matt T
- Thank you received: 276
- fixn_junk
Sounds like you're maybe using one of those bulb style spark testers?
If so, it doesn't place sufficient load on the ignition system to flush out a weak or borderline coil.
This is the only tool I trust for that job.
I am also very skeptical of Ford misfire codes and usually end up testing them all to make sure I don't miss one get ready to crap out.
- fixn_junk
- fixn_junk
I am using the bulb style. If the injectors are shutting down to save the cat is the issue in the cylinders that the injectors are shutting down? All plugs and boots are new. The coil on 7 is new. The one cylinder that has thrown codes the whole time is 7. I didn't get codes for 8 until I pushed it hard. I'm not sure what to do with this thing at this point.
It's going to kill the injectors on the cylinders it thinks are misfiring. So, if it's wrong, it's going to kill the wrong injector. The misfire counter isn't always wrong, I've just been bit enough to not trust that it's not always pointing to the only cylinder with a problem.
The adjustable spark tester stresses the ignition coil in the bay like when you go out on the road and push it hard. #8 coil could be marginal and only failing under load.
Like Matt said, try swapping #8 coil to another cylinder and see if the misfire follows.
Ideally, move it to a cylinder that isn't next in the firing order.
The firing order is 13726548, I would probably move it #5 since it isn't the companion cylinder to 8 and it isn't adjacent in the firing order.
Aside from the ignition system, is the misfire felt constantly or only under load, or only at idle?Have you thought about a compression test in #7 since it's the one coding most often?
You've probably seen Scanner Danner do a clear flood crank where you hold the gas pedal to the floor to disable the fuel system and give it a long crank listening for any kind of uneven sound in the cranking cadence that would point to a compression issue.
- fixn_junk
I have not seen the clear flood crank yet. I've only watched a handful of videos so far. I plan on watching them all but only have so much time.
There is no misfire felt at all until the injectors are cut out on 7 & 8. It runs real smooth until that point at low idle, high idle, and under load. I also do not get codes for 8 until the injector cuts out. Fuel trims hang to the positive with bank 2 running a little more lean, 2-5 short term and 5-7 long term. Running down the road the short terms both run pretty close to 0 but long terms stay around 5. I was thinking about doing a compression test on 7 last night. I will get it back in to do a compression test and swap coils.
I am using Auto Enginuity and it's a little frustrating on this pickup because it doesn't give me the option to monitor misfire counters in live data. I have to go to mode 6 where I just get a snapshot and I'm not sure what the time parameter is for the snapshot. I will post some of the data that I can pull up. Some of it may be my inexperience with it but it sure gives me a lot more on other vehicles.
- fixn_junk
- fixn_junk
- Cheryl
- fixn_junk
- VegasJAK
- Silencing the Parts Cannon
- Thank you received: 140
If no scope, swap the injectors on 7 and 8 and see if misfire follows. Just to rule it out.
Also, in the last round of testing I found the misfiring goes away under load, also stated above. From the research I've done, it seems an ignition related misfire gets worse under load.
That kind of sounds the opposite of what you said when #8 flagged a code when you drive it hard?
I'm not picking on you, trust me! I've been beat up by plenty of 3 valve Ford misfire complaints.
It's been my experience that misfires at low rpm that improve with higher rpm are generally mechanical in nature. Typically valve sealing.
Not sure why power breaking the engine would improve the condition. Strange...
I like ScannerJohn's suggestion of moving the injectors just to get it off the table, assuming you don't have the capability to scope test. He does have an excellent track record
If that doesn't effect anything, considering the misfires are on the same bank, I'm always worried about a VCT issue. They quite often won't set cam timing codes for whatever reason.
Here's a series of videos on YouTube that I have found particularly helpful.
(I may not have linked them in the correct order)
- fixn_junk
Those engines can be very tricky.
It's one thing to be there and experience the fault in person and quite another to try to give useful advice over the internet. It's easy to misinterpret someone's intent in this context. If I said anything that you felt was aimed at belittling you or your skill, than I truly apologize.
Nobody here will ever disrespect you for not knowing something, or for not having millions of dollars tied up in scopes and scan tools.
I realize you're out of your comfort zone. That sucks, I feel for you.
If you need to bail, I get it. But this is an inclusive community, if you choose to continue to interact you are most welcome.
Best of luck to you. You CAN do it.
- VegasJAK
As Noah explains, the network of DIY'ers and experts are here to give you advice and guidance to help solve your problem. Don't feel bad or embarrassed that you do not have the myraid of tool that others have. Part of the ScannerDanner way is to be able to diagnose without those sophisticated tools. Paul can do it with a test light and a multimeter. Some times a test light alone. That's a real professional. I strive to achieve what he's already accomplished.
Please get back to us.
- fixn_junk
- VegasJAK
