Nissan frontier no injector pulse
- mace93
9 years 6 months ago #8056
by mace93
Nissan frontier no injector pulse was created by mace93
Hi guys, i have a nissan frontier 2002 3.3 v6.
I got a intermittent crank no start issue.
Sometime the truck won't start because it loses injector pulses. I have power to the injectors but not ground when cranking.
I thought it can be crank or cam sensor issue, but i get rpm signal and spark(tested with started fluid)
What it can be guys? i am lost.
please help me. thanks
9 years 6 months ago #8068
Replied by Tyler on topic Nissan frontier no injector pulse
Moved this to the Repair section.
No trouble codes stored? I figure you'd have said so if there were, but I gotta ask.
- cheryl hartkorn
- Thank you received: 130
9 years 6 months ago #8070
by cheryl hartkorn
Replied by cheryl hartkorn on topic Nissan frontier no injector pulse
probably an immobilizer issue. if you have cam and crank signals... maybe when it happens again try a different key
- mace93
9 years 6 months ago #8075
by mace93
Replied by mace93 on topic Nissan frontier no injector pulse
i don't think. the key is a simple one, just metal no chip on it.
- cheryl hartkorn
9 years 6 months ago #8081
by cheryl hartkorn
so is there any trouble codes??
- mace93
9 years 6 months ago #8086
by mace93
no trouble codes
- borntoroll
- Thank you received: 9
9 years 6 months ago - 9 years 6 months ago #8119
by borntoroll
Replied by borntoroll on topic Nissan frontier no injector pulse
All 6 don't fire? Verify computer's powers and grounds.
Last edit: 9 years 6 months ago by borntoroll.
- gav09
- Thank you received: 24
9 years 6 months ago #8138
by gav09
Replied by gav09 on topic Nissan frontier no injector pulse
Do you have a scope to test the cam and crank sensor? I can't remember off the top of my head but does this have a distributor? Had one with bad random misfires affecting the injectors and it was dust blocking the holes for the optical sensor inside the distributor
Time to create page: 0.405 seconds
